82 280zx intial start issue
Old 11-16-2013 | 09:15 PM
ScCoghill's Avatar
my 82ZX N/T idles rough for the first minute then clears up with throttle. The FSM is kind of vague on checking the air control valve, can someone at least point me in the right direction? 136K miles, new fuel filter, plugs, injectors. The air flow meter checked okay.
Thanks,
Scott in S.Carolina
Old 11-17-2013 | 07:21 AM
silverzxbullet's Avatar
Pull out your cold start Injector and clean It along with both sides of the electrical connectors for It and The Air Control Valve. That worked for me. Also check your Afm To TB Boot for Unmetered air or any where else for that matter.
Old 11-17-2013 | 10:07 PM
^^^ This.
An n/a rough cold start is either a faulty thermotime sensor / cold start valve, or faulty / leaking air regulator.
So:
#1: After cold starting, pinch hose between throttle body and air regulator. The idle rpm should drop. If not, the air regulator is not functioning (stuck closed). If it does, move to following step:
#2: Pull cold start valve & clean. Start car, no change: test thermotime sensor (Heat / Ohm test).
FSM screen prints:
Attached Thumbnails 82 280zx intial start issue-airreg1.jpg   82 280zx intial start issue-csv1.jpg
Festus Portnoy
09-02-2015 01:54 PM
isoulride
01-03-2014 12:55 PM
Jonathan Ray
07-06-2013 10:23 PM
moorebl
04-14-2011 04:28 PM
Sixer
04-15-2010 04:59 PM
