83 280zx non turbo problems
Guest
Posts: n/a
i got a small problem....i got a 1983 280zx n/a and it had been sitting for a year or so and it was running but then all of a sudden she wouldnt turn over.....the fuel pump isnt getting power....does any one have any clue why it would do this?
Sounds like you have no power to the starter and fuel pump so maybe there is no power to anything. Does your voltometer show any power in the battery?
Check fuses and the fusable links. Check and clean your battery connections on the battery and on the car/starter.
Guest
Posts: n/a
alot of stuff gets power.....the voltmeter doesnt show power but lights turn on she dings when yoou open the door....she tries to turn over buut cant....the fuel pump is the only thing i see that doesnt get power.....the fuel pump works cuz when i hook it up directly to a power source it works....but she still wont start....i am dumbfounded.....she worked saturday....help me please
Try swaping around those relays in the relay box up near the right headlight. Those do things with your charging and electrical system. Maybe the fuel pump knows that the fuel pressure is up and doesnt' need to come on untill you start cranking the engine.
Make sure the battery is fully charged; use a battery charger or voltometer to make sure.
If the starter tries to turn, then either your battery is almost dead, the connection is too weak (corroded), or your engine is siezed.
Originally posted by NwZXlover
engine seized what does that mean...that doesnt sound good....
Maybe unplug or cut the power wires to that fuel pump. Tape the ends of the wire still on the car just to make sure they don't ground out if they do get power. Then power the pump from another battery you have next to the car. For a battery outside of a car, don't set it on the cememt floor. Put it on a wood block on the floor.
That'll let you know if the pump even works at all. Oh, and a siezed engine is not good. That's when something breaks inside and jams so that it wont' spin around (turn over). Usually that happens to an old engine or one that runs out of oil and is being driven on the freeway with a 4-speed. Sometimes you get a rod thrown through the oil pan and lots of smoke comes out. Its not fun! I actually don't think your engine is siezed. That will typically happen while you are driving and you need the car to be towed home.
blockmaster
11-07-2013 02:30 PM
jrlogan280z
05-08-2010 08:23 AM
