83 Turbo idle adjustment screw location?
Old 06-26-2009 | 10:39 PM
83Zturbo's Avatar
Like the title says... Where is the idle screw adjustment on the Turbo motors. My haynes manual has it in one spot but it is definitely not there on my car any help would be sweet.
Old 06-26-2009 | 11:13 PM
Originally Posted by 83Zturbo
My haynes manual has it in one spot but it is definitely not there on my car.
The idle screw pictured in the Haynes manual is for the NON-TURBO. The 280zx turbo idle is controlled by the ecu. The only other way to adjust the idle is by adjusting the throttle body stopper screw.
Old 06-27-2009 | 06:19 AM
83Zturbo's Avatar
Thank you very much kind sir!
Old 07-03-2009 | 09:31 PM
rogerz's Avatar
Grumpy & Helpful
which is underneath and hard to spot but keep looking.
Old 07-08-2009 | 08:26 AM
PooFlinginMonke's Avatar
I usually replace that screw with a slightly longer one that has a hex head and found a jam nut that was a bit thicker.
Most of the time, I just hold it all the way open and twist the tang that meets the stop screw with a small pair of channel locks since most of the screws are siezed.
emo236
26
12-02-2011 01:54 PM
kiboy6
12-13-2008 02:53 AM
Spurs212095
08-09-2007 07:29 AM
vvillium3
03-01-2005 08:37 PM
