Alright, I Cannont Figure It Out! Grrrr!
just when i thought my car was running beautifully its starting to mess up again, ill start off with what i did recently to get the 82 280zx turbo running good, i replaced as many wires and cleaned as many contacts i could and cleaned up the ecu and it was running perfect, now the car bearly accelerates, i can hear the turbo spinning, but it doesnt accelerate, then when enough pressure builds up, i hear a poping noise.??? i think the popping noise could be the BOV, its the original, and i lifted the cap up and let it go and it made a similar noise that i was hearing, so i think that it has to be with the air building up pressure and not releasing right, what do you guys think, ive been working on this problem forever, replaced afm, all vacumm lines, ect.... what else could it be.
Do you have an air/fuel gauge hooked up? Have you set the timing to 20 degrees? And the stock 280zxt doesn't have a BOV... just an emergency pop off valve on the intake manifold. It chirps like a squirrel when you're boosting too much.
Definitely check your timing. This sounds like the problem I was just recently having. The previous owner had put in an entirely new distributor, cap, and rotor after I guess the old one kinda crapped out. He set the timing and it was doing this. Problem was he set the timing with the Throttle Position Sensor still connected. Make sure you disconnect the TPS when setting your timing.
If you look at the crank pulley from the passenger side of the car, you'll notice there's a little plate alongside the crankshaft pulley. It has notches and numbers. Every notch is 2 I believe. You need to find 20 on the plate and mark it with white out or something visible.
corroded fuel injectors clips ? my 280zxt had them.. and some times the fuel injectors didnt want to fire.. so i took a long flat head screw driver and put it onto the plastic part of the injector and held the plastic end to my ear to hear the " clicking " sound a fuel injectors makes when its opening and closeing right...
workingprogress
05-16-2011 01:04 AM
DSR300zx
06-04-2006 09:51 AM
Captain caveman
07-24-2005 09:49 AM
