can someone look at their starter for me???
hey all,
just got my motor in my car, and I didn't label my starter(everything else but that and the alternator). I thought for some reason I would remember how it hooked up after 6 months....
so could someone tell me where there ground wire or positive wire goes on the solinoid...
thanks,
Jason
thanks,
Jason
There are only two wire that go to the starter/solenoid. One is the main battery cable (+) and the other is a smaller (I believe yellow) wire that uses a spade connector to connect to the solenoid. Hope that helps.
Originally Posted by DoTheDrew888
The negative battery cable grounds on the top bolt that is used to bolt the starter to the tranny.
El_Colombiano
01-18-2013 03:36 PM
AlongCamePeter
09-12-2004 06:20 PM
