Can't exceed 4 lbs of boost..?
Hey,
I just finished a turbo swap on my 83 280zx. The engine is from a 81 & runs great, starts up quick and runs smooth.. my only problem is nomatter what i do it refuses to go past 4-5 lbs of boost.
I've triple checked for vacuum leaks and everything is solid. I've also plugged the pov, blocked the egr replaced the fpr, put new plugs and wires, dizzy cap + rotor and double checked the timing.
Right now i have no exhaust besides the stock downpipe, but i don't think that would impact anything. I'm also using a aftermarket boost gauge and mbc. I had the mbc given to me... it looks like a ebay pos and when i took it apart there was no spring and ball.. just a rod that screwed down to block air.. here's a pic of it.
Also this is currently hooked up on the wastegate / intake. I've also tried it on the turbo with no difference.
beyond that all i can really think of is a faulty wastegate actuator, it seems pretty tight and in working order.
any ideas here? this is driving me nuts.
Moved thread to S130 280zx section since your car isn't an S30.
#1: MBC's suck. They aren't reliable.
#2: Are you sure your aftermarket boost gauge is working correctly? Do you still have the stock boost gauge hooked up?
#3: Put your emergency release valve (POV) back on, shut the boost controller completely, and see if it will then boost higher (the POV will open and chirp wildly when boost gets to about 8psi.
the turbo spools like a champ and sounds like a harrier jet when i drive so i'm assuming it's good to go.
I'm going to go close the mbc and drive it in a few, then just plug the wastegate actuator to see what happens.
I'll be super careful though and if i see it go past 5 I'll assume it's the ebay mbc.
pray for me
pray for me
loud turbo isn't always good, loud could mean its dying or its spooling so damn high trying to compensate for a boost leak. no bueno! try removing the MBC all together and just route the line from the compressor to the waste gate like stock see if that solves the problem. and with a line you know has no leaks in it
well the turbo is loud because the car is currently rolling with no exhaust.
i took it out and here's what happened....
with the mbc hooked up and closed there was no difference.. 4-5 and thats it.
I took the hose off of the wastegate and i would get around 5-6 psi, the boost gauge flutters around like mad then I hear a crazy chirping noise coming from under the left side of my hood, followed by a dramatic loss in power. I'm assuming thats the pov kicking in and saving my engine from disaster.
The car definately isn't hitting 8 or 9 psi so could that be a old faulty pov?
Also now that i think about it the last fuel pump on my car died while it was n/a and i replaced it with what i think was a turbo one.
After driving it a few times here's what i think it is.
i get flawless happy gofast boost until 5 psi, after that i notice the engine gets a bit boggy and the power goes away. My money says that i still have a n/a fuel pump from the original 83 setup and possibly a faulty pov. I put the plug back in and took it for a drive and it did perfectly fine until the 5 psi bog point.
That fuel pump definitely wouldn't keep up with the turbo and engine at that point, right?
what fuel pump should I replace this with for optimal fuel delivery so this will never be a problem again?
it all ties around the 5 psi point from what i've seen, never noticed any problems otherwise.
Just kinda seems like the fuel system is like "what the ****?!?!" when boost hits too hard and the fuel pump can't keep up.
I've ran the rpm up to about 5500 with no issues whatsoever. Whats a decent pump to get on these? I'm assuming a walbro or something to that effect.
I got the fuel pump and boost controller in and that seemed to fix it!
The car is fast, hits 7-8 psi and feels great. The only thing i may need to do is plug the pov... whenever it's hooked up the car leaks boost out around 6 psi and when it's plugged everything is wonderful.
Also.. I ran some seafoam through my intake and I thought the fire dept was going to get called on me lol! that stuff smokes like a ****.
quick question.
Are these cars going to make a purge noise like a bov after you let off the pedal?
I noticed my car spools up then makes a blow off noise when i let off from full boost. I'm not a turbo noob by any means but i've never seen a car that blows off with no bov.
The only thing i can think of is my wastegate opening since I am currently running open turbo for exhaust and it's just F'n loud to begin with.
do you have an aftermarket filter on? you might just be hearing compressor surge. does it make a pulsating sound of air not to loud but noticeable almost sounds like a pulsating whine or higher pitched grunt?
http://www.youtube.com/watch?v=nCj6Spwl1CU
this one is a bit more realistic for your application its the quick woopapapa. sound.
http://www.youtube.com/watch?v=OuNTnA5A2Fo
and here to, this car has no BOV on it so you can't mix the two sounds up its ALL surge in this video
http://www.youtube.com/watch?v=LZUbo...eature=related
