car wont start
Old 10-26-2012 | 01:04 AM
wickedminded420's Avatar
car wont start
I had my car start for me the first time now it won't start it has spark is getting gas but won't fire and firing order is set correct 1-5-3-6-2-4 its a 82 280zx
Old 10-28-2012 | 12:52 PM
Welcome to ZDriver!
You're almost there...
An engine needs PROPER air, fuel, and spark to start.
Have you verified spark and fuel at all cylinders?
Old 10-28-2012 | 04:59 PM
rogerz's Avatar
Grumpy & Helpful
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
battery is the heart of your electrical system. if it isn't aone shape you got a problem
moorebl
04-14-2011 04:28 PM
ZXT83
10-03-2009 02:07 PM
dreamspawn
12-20-2008 11:15 AM
JaYaYsSoHN
12-29-2004 01:58 AM
rickyTT
09-26-2004 07:11 PM
