Car wont start anymore at all (ignition)
Old 01-31-2005 | 08:56 PM
sk8ur_9's Avatar
It takes about 30 turns of the key jus to get the engine going and running and after it turns on it runs perfect... but my question now is that I replaced the ignition coil, starter,solinoid,cleaned the alternator wires, the positive/negative cables and checked everything with a multi-meter, but is ther any ground wires i need anywhere, because the starter does not have any grounds wires, just the positive cable, the wire from the tranny (inhibitor),and the wire from the solinoid to the starter itself.any comments..(thnxs in advance)
Old 01-31-2005 | 10:43 PM
icice9's Avatar
Super Siver & Black Stud
are you saying that the engin wont turn over when you turn the key.. or does the engine turn but wont start.. if it wont turn and you gotta keep turning your igniton switch then most likely its your ignition swith.. thats whats wrong with my car.. so i just wired a push putton start.. now no more problems.. but if your engine turns and just wont start.. then thats a whole other problem...
Old 01-31-2005 | 11:24 PM
Heat Rave R's Avatar
I was thinking of a push button starter too since my ignition switch is kinda wonky. Was it difficult to find and work with the wiring for it?
Old 02-01-2005 | 09:03 AM
Yup, I had to replace mine too. Its not the tumblers but the part on the back of them that has a bad connection.
Importedcarparts.com $28 right now. Cheap!
part #M5050-20783
Old 02-01-2005 | 01:46 PM
sk8ur_9's Avatar
when i turn the key u can hear the gas pump on and when u turn the key to actually turn on the car it does nothin at all doesnt turn either (thnxs tho ICICE)
Old 02-01-2005 | 02:00 PM
icice9's Avatar
yup thats your ignition switch... same problem as mine...
Old 02-01-2005 | 06:37 PM
part #M5050-20783
Does this necessitate getting a new/different key?
Old 02-02-2005 | 11:07 PM
NO! No new key.
Old 02-03-2005 | 11:53 PM
lww's Avatar
lww
Head Muckraker
You need to either clean the contacts on the ignition switch (the part the key goes into) or get a replacement.
Old 03-25-2005 | 01:10 PM
sk8ur_9's Avatar
well i got it fixed i just did it my self... i just rewired the ignition to a push button like ICICE9 (thnxs) and well it turns on like new
plainwhiteZ
05-11-2013 01:20 PM
moorebl
04-14-2011 04:28 PM
traethetruth
01-05-2011 06:31 PM
yeaiwonder88
05-11-2006 07:20 AM
FireDhusky
07-01-2004 10:36 PM
