Charging issues
its a 60 amp altenator, im not sure what its putting out, do i use a multi meter to test that, if so how? Im still learning how to work on cars here, also, i test it while the car is running correct?
A car battery should be @ 12.6 volts. If your alternator is putting out 12.3v, you are technically draining your battery. Alternators should put out 14 to 14.5v. If it's not, the alternator or voltage regulator is toast, or there is something funky w/ the charge wire.
It's internal in the 280zx's. If you take it to an alternator shop they can probably repair it, otherwise you just get to buy a new/reman alternator from your local parts store (either way will be about the same cost).
It is easy to change it out so don't worry.
You can change just the voltage regulator but you have to tear into the alt and do some soldering at the bottom of it inside. If its new it should be exchanged because its not your problem to be fixing a new alternator.
Unfortunately this is the only picture I have of mine, this was when I first put them in:
IMG_3189.jpg?t=1254969160
The Beige is an 80, the Green is a 30 that the Reds are 50.
Here's the Atlantic Z Car link:
http://atlanticz.ca/zclub/techtips/f...nks/index.html
The Schoche blocks are about $9 at Walmart.
