Clutch and Wheels
Old 08-29-2006 | 08:30 PM
Nemesis280zx's Avatar
Clutch and Wheels
I was wondering what people prefer as in a clutch for an 83 280ZX Turbo with about 280HP. What do you guys recommend? Also how wide of a rim can you fit on a stock suspension on the same car? Can you fit a 10in. wide rim? Thanks.
Old 08-29-2006 | 11:05 PM
skittle's Avatar
Taste My Rainbow
The Rims Would Be A Very Very Tight Fit, A Stage 2 Clutch Would Work Fine
Old 08-31-2006 | 10:38 AM
Whats the biggest size that someone has ever put on a stock suspension? Has ten inches ever been done before on a 280ZX with stock suspension? I'm looking to buy 275 drag radials for the track.
Old 08-31-2006 | 11:36 AM
veyenyl's Avatar
15x10 would probably fit but it would have to be close to -40 offset and you would need flares. Something like this
http://classifieds.hybridz.org/showp...t=2972&cat=all
Honestly, I don't think you need drag radials that wide for 280hp.
Old 08-31-2006 | 11:39 AM
I put 10 inch wide in the back. 16x10 zero offset. It wouldn't tuck though, almost... you would need some positive offset. +20 to +30 is a guess. There was quite a bit of room on the inside between the wheel and strut. Not much room between the inside rim and a-arm so 15 inch is not a good idea. 16 or 17 is best.
In the front I've heard 8.5 inch wide is the widest with some positive offset to bring the wheel in a little. How much exactly I do not know.
Carson B
06-01-2014 06:25 PM
LikeZcars
02-24-2013 07:41 PM
decalservice
08-26-2012 01:16 AM
JSimpson
FS: 300ZX (90-96)
07-25-2011 11:59 PM
ml430v8
FS: 300ZX (90-96)
08-20-2007 11:31 AM
