cold air intake ?
The stock set up is already a "cold air intake". I don't think you'd see any noticeable improvement from adding one. Though you'd drop some front end weight by getting rid of the stock air box and it'd look way better too. It's really easy to make your own out of a piece of mandrel bent aluminized exhuast tube and a K&N filter to fit on the end. You might get slightly better air flow and more noticeable intake noise when you step on it with this set up.
It may be worth it just for the weight savings and looks alone!
Guest
Posts: n/a
I still got the crappy *** light blue container, but i stuck a K&N filter in, but not the full K&N filter charger, it was like 60 bucks more for the full deal but the full intake will flow a bit more. Basically since you have the headers and the free flowing straight pipe, you will notice much more of a difference than with the stock exhaust. It may not give you magical hp gains but it will probably give you a few and help balance out the exhaust.
