cold start
Old 09-25-2006 | 09:02 PM
EatmyDust's Avatar
cold start
man let me start off by saying this problem is bullshit. when I crank my car when it is not warmed up, it dumps way too much fuel in. it runs like ****, so I have ben having to adjust my afm to make it run corectly. I boght a new afm, but am having no luck with it. is there somthing I am missing that is making it do this when it is cold? it is pissing me off. I just need it to quit dumping so much fuel when it is cold. I don't know what to do at this point.
Old 09-25-2006 | 09:08 PM
EatmyDust's Avatar
might I add when it dose run when it is cold, it dosn't run long. I have to give it gas to keep it going,then it just fluds it out, causing it to not run at all.
Old 09-25-2006 | 09:54 PM
Have you already checked/replaced the air regulator?
Old 09-25-2006 | 09:58 PM
RodMoyes's Avatar
Doesn't post much...
^ Yup... Beat me to it!
Replace the A R and see what happens.
Rod
Old 09-25-2006 | 10:00 PM
Rod knows whut up.
Old 09-26-2006 | 05:09 AM
EatmyDust's Avatar
Ok this is going to sound stupid but I didn't know there was an air regulator on this car. where is this now?
Old 09-26-2006 | 08:07 AM
It's on the top of the intake manifold. It a lookie a like thees:
Old 09-26-2006 | 11:19 AM
the AFM itself can affect your cold starting too. Make sure you don't put water all over the Air Flow Meter. Read Bleach's Z tip of the day in the Off Topic section. I already went over this!
haha
Old 09-26-2006 | 06:11 PM
EatmyDust's Avatar
well the new afm wont even let the car run when it is warmed up. I am runing on the old one now. I want to ask what is the purpos of the auxilary air reg? I will look it up in the chiltons, but I would like to hear you guys's perspective. I took the new afm to my budys z restor shop and he told me it is the rong afm, and that it is for a 510. now if this is true, why is the reman I have on it that is leting the car run the same one same part number, same down to the t. this reman was on the car when I boght it, so either he didn't take a good look at it, or I have the rong one on it now, but that wouldn't explain why it runs with the old one and not the new one.
Old 09-26-2006 | 09:49 PM
EatmyDust's Avatar
well I see that on the scamatic that the auxilary air is wired into the efi like the afm. I still don't know when it is powerd, what trigers the power up, and what it is suposed to acomplish, besides leting air past the throttle plate, without having to go through the plate. Is the auxulary air suposed to have manifold vacum to it? when I put manifold vacum to it, it idles up a good bit.
Old 09-27-2006 | 08:41 AM
well, I'm not sure how he knows it is for a 510 unless it looks physically smaller. Wait a sec... the first and second gen 510's all had carbs!
Take that Hitachi carb off your Z! hehe
I've swapped a couple 280ZX AFMs but never earlier ones from a 280Z so I'm not sure how well they might be swapped around. The mid 80's 200SX I believe has a AFM of the same style but for a 4-cyl. The BMWs from the 80's use the Bosch FI system with a flap AFM too... not that it'll work on your Z but they might interchange enough to make you think it'll work.
Old 09-27-2006 | 03:23 PM
duowing's Avatar
NisTuner
If you haven't fooled around with the Remanned AFM it might actually be that your car has more problems then you think and the fact that you've been messing with the other one has just compensated for the other problems. Just a theory, but that theory seemed to be right with my car...
Old 09-27-2006 | 04:51 PM
EatmyDust's Avatar
well its the right one, the only problem is that I can see with it, is that they set the spring tention way to loos. that is why it floods out.
Old 09-27-2006 | 05:01 PM
lww's Avatar
lww
Head Muckraker
Using the BMW AFM in the 80's was a very common cheat in SCCA club racing. You got much better flow out of the BMW from it's greater flow rates and it looks exactly the same on the outside as the stock AFM on the ZX.
Old 09-28-2006 | 02:21 PM
naviathan's Avatar
Since this hasn't been mentioned, Check your head temperature sensor. It's between cylinders 5 and 6 on the passengers side of the block. When it's disconnected or not functioning it will make the car run really rich.
Old 09-28-2006 | 06:04 PM
RodMoyes's Avatar
Specifics please!
Exactly WHAT BMW afm is the one that you are referencing?????????
I want MORE POWER!
Rod.
Old 09-28-2006 | 08:36 PM
jfairladyz's Avatar
^ then get a tur... aww, forget it
Old 09-29-2006 | 12:17 AM
RodMoyes's Avatar
Lizik muh-bizalls!
Turbo swap will happen someday, just not someday soon.
I will have my all black 96 Z32TT before I do a turbo swap on the S130.
Rod.
Old 09-29-2006 | 12:42 PM
~1983-91 BMW 325i
It is a 2.5L straight six
If you find one in a yard, see if the FI clips are the same type but a better connection. Grab other stuff. then set the car on fire when you have what you want.
Old 09-29-2006 | 12:44 PM
muh.... muh.... sweet bimmers... Bah! I hate pre-92 3's anyway
Old 09-29-2006 | 12:47 PM
Its like an overweight Datsun 510. ya, I had one. 1989 four door. ok car, but rediculous on parts prices and no, I didn't see them being more reliable than every other car on the road. BMW owners keep ranting on that. My Nissans have been by far the most reliable. I liked my Altima better than the Bimmer.
Old 09-29-2006 | 02:48 PM
GTR's Avatar
GTR
Badass Z Chick
Hijacking threads again, guys? I'm just curious, eatmydust, how many pins does the "new" AFM have? Better yet, I think you outta bring it down to Corpus and let me fix it for you ^.^
Old 09-29-2006 | 04:06 PM
RodMoyes's Avatar
^ I went to Disneyland once.
Rod.
Old 09-29-2006 | 05:06 PM
jfairladyz's Avatar
I wanna go to Disney World. But the price is rediculous (what was the topic here again??? Thread jacking?)
And the only reason I'm not contributing to this post in a meaningful way is because Nismopic and Rod already gave the solution to the problem
Old 09-29-2006 | 05:35 PM
RodMoyes's Avatar
Grapes taste good.
Rod.
