connecting rods
Old 04-14-2005 | 05:36 PM
vvillium3's Avatar
connecting rods
any one here had any luck with arizona z's connecting rods??? I spun a connecting rod bearing and messed up one of the rods and crank journal. I am rebuilding basically stock motor and was wondering if arizona's rods are up to par. I am also going with arp mains,rods, and head sets with a .020 under crank. Don't really plan on going much higher then 15-17psi on the weekends. What else out there do you guys reccommend that I should consider. I am on the edge of which headgasket to use(metal or not were and which one)... Done a lot of searching but no definate answers... Let me hear your thoughts and the results of your setups...
thanks,
Old 04-14-2005 | 06:40 PM
DoTheDrew888's Avatar
I do not have personal expirience with AZC connecting rods but I have heard very good things about them. I think they should be fine. Also, for the head gasket you should get a Felpro. It will raise you compression slightly but not enough to cause any problems. You might even gain a little low end torque.
Old 04-15-2005 | 07:37 AM
vvillium3's Avatar
thanks for the suggestion... I think I will go with that, thanks for your help not too many people here wanting to help the beginners....
jason
soates4
03-07-2014 07:27 PM
snwbrderphat540
02-19-2009 07:13 PM
Chewievette
05-10-2006 05:33 AM
greenmonster80
01-28-2004 11:07 AM
datsun280zx_81
01-07-2002 03:15 PM
Quick Reply: connecting rods
