A couple mod questions
Hey guys. First of all, does anyone know where I can get a short throw shifter for an 81 280zx? Also, I'm thinking of getting the Crane cams XR-700 electronic ignition system from motorsport auto. How hard is it to put in? I'm getting a check for 1,400 bucks and about 1,200 is going in the 280.
The ignition: if you know how to follow wiring diagrams, and can hook up wires, I think you'll make it.
NO ONE make a short throw shifter for the 280zx N/A because all the linkage is in the bell housing.. Sure you can make a shorter lever but you wont be doing anything for the linkage to actually shorten the throw..
http://www.zcarparts.com/store/merch...ry_Code=PRC02A
Motorsport auto doesn't have one for an 81 280zx
I've got a short shifter Made it myself. All I did was hack the old one and weld it back together. I'll take some pics tomorrow and try to post em. It was really easy to do and the 3rd gear shifts are much easier since I don't have to shift so far. It doesn't do much else for me though as the throw of the linkage wasn't changed, just how far I have to move my arm. I'll take a pic of it next to a stock shifter so you can see the difference.
On a side note; It would probably make shifting into 5th easier too but I only have a four speed so I can't attest to that one
What did you use to weld it? TIG, MIG, Oxy? I might try that. Now, does anyone know how hard it is to put in a Crane Cams electronic ignition system?
IF you can follow wiring diagrams & can hook wires together... you can hook up a crane ignition
Well, I got the hooking wires part down. but my friend could probably help me out on that one. You don't have to be rich to have a tig welder. you just have to have a friend taking college welding classes and weld pretty good.
Actually, it's a little thick for TIG. I wouldn't recommend trying TIG unless you want the shaft to snap off on a hard shift. . I used Stick for this one. TIG is really only good up to about a 1/4" thick. After that you lose all the benefits of using it in the first place(if you can even find a TIG tip to weld that thick). But just plain old gas torch welding would work just fine for this one. It doesn't have to be pretty (it gets covered by the shift boot anyways ).
Man I can't wait to get me a new welder. That shifter was actually the last thing I've welded since I left CA. I sold everything I own except for a few handtools and the Z when I moved out here. I gotta lot of fabbing to do
Check out:
http://store.summitracing.com/defaul...=egnsearch.asp
http://www.jegs.com/webapp/wcs/store...archTerm=xr700
Many parts for sale at MSA for our cars are generic and work with any car, given the right configuration. These large parts suppliers have a HUGE market and can buy and sell at reduced prices as a result of the volume.
Nearly everything MSA has for sale is available cheaper elsewhere. But sometimes, the convenience is worth the price difference. But do it because it's the right decision.
Cheers,
lww
Originally Posted by lww
What welder are you going to get?
Before you buy from Motor Sport Auto check the prices at the other big auto parts houses before you pay the premium MSA asks.
Check out:
Cheers,
lww
Check out:
Cheers,
lww
Here's some pics of the short shifter I was talking about that I made. One is a comparison of it with the stock shifter. The other picture is just the short shifter. You can see where it was welded as it's rusting now that I'm living here on the eastern seaboard
Works great. I like it a lot more than the stock one. It doesn't look like much was taken off but when you figure in how far you got to move it from 2nd to 3rd the difference is huge. You just gotta make sure you get pretty good penetration on your welds or you might end up snapping it. Like I said, I didn't use the prettiest form of welding but it did do the trick. I probably should've coated it with something though so it didn't rust though. Oh well, lesson learned for the next guy. Next up I'm gonna raise the pivot point on the transmission and extend the lower part of the shifter. That way I'll get a real short shifter. Got get me a new welder first I know you've got links L-Dub. Where you at?
I wanted to make real short throw shifters but I'm still coming up with ideas for raising the pivot point. It's tough on the Nissan 4 & 5 speeds cause of their design. And then it's gotta be reliable and easy enough for the general public to install and use. Which means it can't be weld on
