Crankshaft Pulley Bolt
Old 03-08-2010 | 12:49 AM
Cali79zx's Avatar
I can't seem to get this damn bolt broken loose. Any suggestions on: 1) How to keep the engine from turning? and 2) How to break it loose period?
Btw, the engine is still in the car, not taken out.
Thanks for the help
Old 03-08-2010 | 06:35 AM
The easiest way is to use an impact gun.
You can also put it in 5th gear, pull the ebrake, have someone standing on the brakes, and have the wheels chalked, while you use a breaker bar and "cheater bar" extension.
You can also do it the slightly more dangerous way of wedging the breaker bar / cheater bar against the ground, or hold it against the frame, and give the motor a quick start with the key (COIL WIRE TO DIZZY UNPLUGGED OF COURSE).
Old 03-08-2010 | 07:57 AM
Cali79zx's Avatar
What if its an automatic transmission?
Old 03-08-2010 | 08:03 AM
Then put it in DRIVE / 3rd gear... and do the same steps. I would hope that you got the general idea of putting as much resistance as possible to the drive train... so you can put that much resistance into breaking the bolt loose. Get it?
Old 03-08-2010 | 08:07 AM
Cali79zx's Avatar
Got it. Thank you
Old 03-11-2010 | 04:36 PM
Cali79zx's Avatar
So I am running into another problem. I can't get the engine to stop turning. I have taken all the steps Nismo suggested and the engine just keeps turning. Do I have a whole other problem or what? Any advice would be helpful. Thanks
Old 03-11-2010 | 05:14 PM
I take it you didn't try the impact gun nor cranking the engine methods?
Old 03-11-2010 | 05:15 PM
280zx2by2's Avatar
Haterade by da gallon!
Yeah I tried putting mine in 5th-1st, reverse everything. I had to use an impact.
Old 03-11-2010 | 05:17 PM
280zx2by2's Avatar
He might not have an impact gun and he might have the timing chain/sprocket off of the cam as I do.
Only leaves the (go buy or borrow an) impact gun option.
Old 03-11-2010 | 05:22 PM
Cali79zx's Avatar
I don't have an impact gun and the entire reason I have to do this is because the timing chain lost slack and the tensioner came off. So I can't turn the engine over right now.
Old 03-11-2010 | 06:06 PM
280zx2by2's Avatar
Well unless you can locate an impact you might be screwed...
The haynes manual says something about using a flywheel locker but I have never used one.
Old 03-11-2010 | 07:18 PM
Impact gun is the only option, unless you have a spare tensioner. If you do, use the starter to break it loose.
The last resort method would be to drop the oil pan & wedge a 2x4 block between one of the crank arms and the engine block wall so the crank can't turn. This is the last resort because the oil pan is a beetch to get off on the 280zx.
Old 03-11-2010 | 07:40 PM
Cali79zx's Avatar
Alright, well I just tried to wedge the breaker bar and crank it over...
and some how managed to crack the entire bottom half of the front cover off.
hahaha. and the bolt still isn't broken. Pick n Pull here I come.
I'm just gonna invest in an impact wrench. Thanks for the help guys.
Btw, one of my friends suggested a swap with the sr20det. Good idea or no?
Old 03-11-2010 | 08:15 PM
You wedged it on the timing cover??????? As I stated above, only wedge it on the ground or frame.
As for the SR20DET... NO.
Old 03-11-2010 | 08:19 PM
Cali79zx's Avatar
lol is there any way to even wedge it to the timing cover???
I wedged it to the frame. I honestly don't know how the timing cover cracked.
If you were to swap the motor, what would u suggest Nismo?
Old 03-11-2010 | 08:26 PM
Wow... I'm amazed that the timing cover cracked.
The SR20DET or KA24DE(T) works well in an S30 (240z-280z) body, not a 280zx body. Watch this video for the reason why: http://www.youtube.com/watch?v=8SmelhOoS1g
For the 280zx, keep it inline-six, either an L28ET, L31 Stroker, or RB26DETT (if you have gobs of $ to spend).
Old 03-11-2010 | 10:18 PM
Cali79zx's Avatar
Alright, well I got the pulley bolt off so that's good lol. Just need to order a new timing cover and I'm good to go.
Old 03-12-2010 | 01:39 PM
280zx2by2's Avatar
Or go V8-V6...
I personally would go VG or VQ for a v6, FI 302 for a V8.
L6 = over rated, who really needs near perfect harmonic balance when you get most of your HP/TQ at low rpm?
Old 03-12-2010 | 02:25 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
I used a strap wrench on the crank pully, along with putting it in gear, parking brake and chocked the tires. Worked without too much fighting... Sucks you had to break stuff to get yours off.
Old 03-12-2010 | 10:55 PM
Cali79zx's Avatar
Yeah it does suck it broke lol, but I ordered the new timing cover today so it should be here in a few days. Will post a pic of the timing cover tomorrow
Old 03-13-2010 | 09:04 AM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
where did you order one from? I hot tanked my front cover and had to get a used one for $80 how much and where with you?
Old 03-13-2010 | 12:12 PM
Cali79zx's Avatar
I ordered mine form zcarsource. Thats the only place I could find. It was used and it cost me 160. Ordered it last night. Its coming from phoenix so it should be here in a few days
Old 03-13-2010 | 12:17 PM
Ouch! $160?
Late news... but maybe use this info next time. You could have scored one from a junk yard (most likely already pulled) for $35-$50.
www.car-parts.com
1979
Timing Cover
Nissan 280Z/280ZX 09038 $50 One Way Auto Salvage USA-CA(Alhambra) Request_Quote 1-626-289-5696 Request_Insurance_Quote
1982
Timing Cover
6960 $50 Standard Auto Recycling USA-CA(Chula-Vista) E-mail 1-619-426-1166
1981
Timing Cover
Nissan 280Z/280ZX 440207 $40 Merrell's Auto Dismantling, Inc. USA-CA(San-Bernandino) Request_Quote 1-909-888-4768 Request_Insurance_Quote
1974
Timing Cover
Nissan 260Z 09080 $35 One Way Auto Salvage USA-CA(Alhambra) Request_Quote 1-626-289-5696 Request_Insurance_Quote
1980
Timing Cover
3380 $35 Standard Auto Recycling USA-CA(Chula-Vista) E-mail 1-619-426-1166
Old 03-13-2010 | 12:33 PM
Cali79zx's Avatar
Wow hahaha well I guess next time I will check those places out XD
Old 03-13-2010 | 05:24 PM
Cali79zx's Avatar
So I had to show everyone this picture
I can thank this to the brillant Datsun designers lol
Woots lmao.
Quick Reply: Crankshaft Pulley Bolt
