Cruise Control
Old 08-31-2009 | 08:19 AM
stiletto660's Avatar
Cruise Control
Hello Everyone,
I have a quick question about the Cruise Control on my 1980 ZX.
My speedo cable is hanging up at times, the needle on the MPH gauge pulsates up to about 40-43 MPH anything above that the needle will peg at either 0 or 80 MPH. My question is can this symptom be one of the reasons why my cruise is not working? I realize that there are several other things that I will need to check ie. Vacuum & Electrical componets but am not sure if the speedo cable can effect the cruise control operation? I have all ready replaceded all the little round pads on the brake and clutch arms that engage & disengage the switches, tested the cruise control main switch, turn signal/cruise control switch on the column. I still need to look at the relay and controller unit under the passange seat and the vacuum soleniods in the engine compartment.
Any other suggestions?
Thanks,
Phil
Old 08-31-2009 | 10:22 AM
Indeed, a jumping speedo could cause cruise control not to function properly. A jumping speedo is usually a kinked cable, dying speedo, maybe the speedo cog in the tranny is loose / stripped, maybe the cable just needs some grease. You'll never know until you tear into it.
Start w/ the basics.
Old 08-31-2009 | 10:49 AM
Thanks Nismo,
I appreciate the response Speedo Cog in the Tranny is fine, I'm going to check the short speedo cable for kinks I have a new spare if needed.
Old 08-31-2009 | 05:00 PM
Niku-Sama's Avatar
eff good grammar
mine used to wobble a bit, pulling in the cable from the engine side of the firewall and taking up the slack seemed to help for some reason
cblevons
08-21-2005 02:44 PM
akshon_muZik
05-18-2005 10:36 PM
Carl's Z
02-16-2004 09:04 PM
kd5izq
10-08-2002 05:06 PM
DMT84T
01-03-2002 10:04 PM
