Cutting my airbox
Cutting my airbox
Ok...so all of the Aftermarket CAIs for the 280zx are positioned in approximately the same place as my stock airbox. What would be the defecit of cutting out the front of my existing airbox, leaving enough metal intact to still screw the lid down without it wobbling around?
The stock ZX air box is already technically a cold air intake.
The black plastic that goes on the intake side of it and into the fender is sucking air from outside of the engine bay. Even on the some where that pieces has gone missing over the years its still pulling in air from the grill area.
Something like a cone filter CAI on a stock N/A 280ZX will get you no noticeable power gains,
just that extra bling point of a cone filter.
The over all effect of cutting your box (Iv seen a few done like that) is a little better air flow into your intake, otherwise its not going to do a whole lot.
Black plastic??
Mine's Blue metal. :P
There's not black plastic on the opposite side of the box from where it goes to the engine bay.
Maybe my Z's missing something.
the box itself is a metal factory blue box, at the intake side of it theres a black plastic piece that goes from the opening in the box to that hole next to your headlight bucket.
I snapped a pic of my ZX air box so I post a pic in a sec, better than trying to explain lol
(good eye hoov)
- Wolf 3D Engine Management
- Custom Fuel Rail w/14mm O- ring injectors
- Sequential Denso Coils
(the 300zx ECU swap is from the Z31 btw)
what? irrelevant.
Explain this pressure checking business to me, what pressure are you intending to check and how?
just humor me.
The stock airbox is already a CAI. Read post #2
I realize that it is a cai, but the point is he's thinking there will be some benefit to modifying it, regardless of whether it is or is not a cai. One of the benefits hyped by many cai types is reduction of restriction, not simply cold air. A pressure check separates fact from garbage.
again, read post #2
I already told him its not really going to do a thing. Any differences it makes will be so minuscule you will never notice.
And a pressure check will either verify or prove you wrong, but at least then HE"LL KNOW, and not be dependent on somebody else's word.
i still dont get this pressure check thing, dont N/A engines create vacuum? also even though turbo's pressurize the air, it only pressurizes it to the TB, so the airbox is always seeing some for of vacuum, so we would need to flow test it, to see how much more CFM it flow's then with it capped off, but either way a stock L series datsun wont benefit from it, other then creating a louder intake noise.
I dont think theres a point to do it. There next to nothing for the intake side. hence why a CAI does about nothing to start with. just put a K&N Filter in your stock box
OT. skib, think you can tell me more about that Z. I think I like that ECU set up more the megasquirt
heres a spec list from that car
Engine: L28 with Euro Flat-Top's
P79 Contundo Circumsonus Head
Customized Air Cleaner
60mm Throttle-body
Custom Intake Manifold/Fuel Rail w/14mm O- ring injectors
Wolf 3D Engine Management system
6 Denso Coils, sequentially triggered
Centerforce light weight flywheel and clutch
The Head and Intake Manifold:
Paul Ruschman of Rusch Motorsports (ruschmotorsports@hotmail.com) is to be credited for work done to this specialty head and intake. The head has been ported, polished and ccd. A stock Nissan intake was used. All protrusions were ground off and openings welded closed. He then relocated and machined new vacuum orifices. The manifold was Jet Coated as are the Headers which have resulted in reduced heat saturization.
The Engine Management System:
Ron Tyler of Prime Engine Management (Ron@primeems.com) not to be outdone, suggested we turn this already modified engine into an even healthier Fire Breathin, Pavement Pounding machine. Ron decided to rip out and throw away the distributor, coil, plug wires and stock fuel injection system. He then replaced all these parts with a Wolf 3D stand alone engine management system.
A multitude of hours has been invested in this engine by Paul Ruschman and Ron Tyler. Without their help this project would have never come to light. After 22 months it is ready.
60mm Throttle-body
