dash "break " light comes on with accelleration
Old 11-16-2009 | 03:24 PM
ananimator's Avatar
1982 ZXT auto
Whenever I accellerate the dash "brake" light come on for awhile.
I checked the break fluid and the handbreak.
Any ideas what ciuld cause this?
Thanks
Old 11-16-2009 | 03:38 PM
280zx2by2's Avatar
Haterade by da gallon!
Make sure one of the floats on the brake fluid resiviors isn't stuck, if that's not it it could be the connection that tells when you have the e brake applied, and worst case scenario you have a short in your wiring some where down the line.
EDIT: nvm just put some more fluid in your resiviors and i BET you the light will go away...
Old 11-16-2009 | 06:39 PM
Niku-Sama's Avatar
eff good grammar
could be a loose connection aswell on one of the switches either for the hand break or the res
Old 11-18-2009 | 10:32 AM
at-jefft's Avatar
Uber n00b!
Yup, low brake fluid. It probably sloshes away from the float under acceleration.
Old 11-18-2009 | 01:44 PM
280zx2by2's Avatar
Yeah that was the clue lol i went about two weeks pointlessly beating my e brake trying to get the light to go out then realized that that light also warns you of low brake fluid.
Old 12-14-2009 | 04:32 PM
chevyss772's Avatar
mine comes on when i accelerate hard also and my fluids not low is this a normal thing to happen to zs ?
Old 12-15-2009 | 01:21 AM
^ Might need to clean the connections for the sensor. That tells you the fluid is low. Just curious. Where does your fluid level sit? It could be when you take off hard. That the fluid could be going right below the sensor spot. Anyway if that isn't it. Check your e-brake wires. Those could be not making good contact. So that it thinks your brake is on. When it actually isn't. Just remove your center console. And the carpet a little. And you should be able to get to the the e-brake wires. Good luck.
Old 12-15-2009 | 08:22 AM
At what level is the fluid? Did you top it off so it sets just below the cap?
different people have a different idea of what too low is for brake fluid.
Old 12-16-2009 | 04:40 PM
chevyss772's Avatar
im a tech nothing gets too low
its full but my ebrake broke
its what i get for letting people try and drift in my z
Old 12-17-2009 | 04:50 PM
im a tech
A computer tech?
TheShanMan
03-08-2014 03:25 PM
PowerhungryBill
09-16-2008 09:04 AM
inqui-Z-tor
10-10-2006 06:46 PM
topdoggcarlos
12-23-2004 06:55 AM
Cronic
12-13-2004 12:12 PM
Quick Reply: dash "break " light comes on with accelleration
