Didnt pass smog!!! need help!
ok, so im a gross polluter now.... my co2 readings were off the chart, my nox was pretty high, well....they were all high, so far, i have replaced the o2 sensor, all vacumm hoses, all fuel line hoses, and flushed the radiator, with new coolant, my next part to add is a new thermotime sensor...? good move? or stupid move? a key element is when i replaced the o2 sensor, it had grey ash on it, meaning its running thin, what sensors could go bad that would make it run thin?? oh, i have a 280zx turbo 82...if that helps any, any help on this one would be much appreciated, as i currently have a fix it ticket for my registration, and i cant get registered without smog...
Well bud, I just went through this nightmare a short time ago. I know pretty sure that NOX is your EGR valve. It could be plugged up, and not functioning correctly. Also for the Co2 readings, you could be running rich, and or your cat could be plugged or bad. Even though I passed with a gutted cat. But I would also check your AFM. It could be faulty, and sending a wrong signal to the ECU. Also maybe your air filter, that could cause richness problems.
I will be honest, I do not know much about Turbos. So don't take this info as gospel. I just figured I would tell you the small things to check out. I am sure a Turbo expert, can help you out more than I can. I know how to dial my n/a for emissions. I don't know if it will work on the turbo. Anyway that is all I can help you with. Good luck to you bro'
This may be a long shot, but many people are raving about it. It may be worth it to try to get your emisions down.
http://www.4ecorp.ws/number1priority/index.php
I love this:
REDUCE YOUR FUEL COST
- Save 7% - 19% On Fuel
- Pass Any Emission Test
sorry for not responding in a while, ive been through hell this weekend, well, i know for sure it isnt the afm because i just installed a brand new one not too long ago, i replaced all fuel hoses and vacumm hoses so shouldnt be clogged up unless clogged in the fuel rail, on thing it must be is the cat, because i recently just cleaned out the entire cat, and i just had a dyagnostics done and it read that the cat is bad...the guy at the shop said just replace the cat and it will pass emissions...so now that i know it is the cat, what type of cat would be best to go with for emissions and also for performance?? and what type? 2-way, 3way?
you can get a high flow 3 way for bout 100 bucks, make it removable so it doesnt ever ware out, thats what i do, that and you can run a couple of liters to a full tank of methyl hydrate, its good stuff, boost the alchol levels in the tank and burns super clean. on a na application you can also unplug #5 injector to make an onboard air pump, the car will still run fine, just dont let them open the hood, or make it so there is a break in the wire. i dont know if that will work with turbo or not tho.
Also, remove and clean every connector to every sensor with electrical contact cleaner and then seal it with di-electric grease. The grease will keep air and moisture away from the connection so it won't corrode as easily.
Use the electrical contact cleaner on your ECU connector as well.
Even though your AFM is new, the connector to the wire that goes to your ECU is probably the same old one unless you replaced your electrical harness as well.
It's very possible that your old connector has some corrosion built up on it. It'll look tarnished and may have a green hue to it.
Most of the reliability problems on these cars can be remedied by following the procedure above. Once that's all done, then you can start replacing parts, although I'd recommend getting a voltage meter and a Factory Service Manual, so you can test them before you replace them...
Good luck.
Good luck.
Don't worry about it. Just find a crocked smog tech and have him smog your car.
My car can't pass a smog test to save it's live. I'm a 98 obd2 car running a 93 harness, ecu and engine, which is obd1. Plus with the tt swap, and the fact I'm running without precats into a straight exhaust with no cat. Then you throw in everything else and I can't even open my hood. But it doesn't matter, my friend takes care of it. So don't worry about it, when there are 100's of these smog techs running around
yeah just cause a tech is willing to hook up one person doesn't mean he's going to do it for someone else. I've been reffered to someones "buddy" before only to be looked at like they didn't know what I was talking about. Getting around a visual inspection is the only part of an emissions test I've ever been "hooked up" with from a friend that knows a friend. But as far as actual emissions output goes, I've yet to meet anybody willing to falsify that part of the test. Of course thats CA.
i really dont mind making it a smog free car, its good for the environment and all that crap, plus the better your emissions do the better you gas mileage is, all bad smog is, is gas that hasnt fully burned off making hydrocarbons, the less hydrocarbons, the more gas that is burning more efficiently.
Good luck.
Good luck.
Originally Posted by PooFlinginMonke
Crap..............I just remembered the wiring harness connectors that plug into the ecu have huge problems on the zx turbos.
I actually cannot remember a 280zx turbo that didn't have this issue.
Thats funny cause my ZX turbo was covered in rust. Floorboards rusted right through. All the electrical connectors were corroded badly. Ground wires were corroded feet into the insulation. All EXCEPT the connector for the ECU. It looks brand new and I haven't had to clean it up at all. It's just funny to me that my car was in such bad shape corrosion wise except for that part.
Yep......doesn't need corrosion to be a bad connection.
I was taking the harness from the latest z31 I could find and repopulating the connector in the proper places to match the 280zx pin out such that I ended up with the contacts being 8 years newer than my 1981 zx turbo.
Sadly.........I find the boards cracked on many of these ecus and no amount of connector tom foolery will fix that until the cracked traces on the board are jumpered or reflowed.
so will the ECU connectors from the Z31 plug directly into the 83-83 turbo ECU's? I'm not neccessarily talking about pins being in all the same order but more so that the actual plastic of the connectors will plug right up to the older ECU's.
