Digital Speedometer reads 0 ! help !
I found a 83 Z with a good body, 109K, 5-speed, t-tops, new carpet and mats still in the box, needs clutch, a/c works, but the car would not start. I put plugs and plug wires in it and it fired up. But my problem is that the digital speedometer lights up but only reads 0. I looked on search but did not find anything. Are there any fuses, relays or speedometer parts that I can check myself ? Has anyone else had this problem? Any leads or suggestions would be helpful. I have stayed away from digital in my other 3 Z's, but the price was too good to pass up.
Digital Speedometer Broken
Is this the same cable that controls the odometer? , because the odometer works, but I just don't get any reading on my speedometer, just says "O".
Where does the reading come from? or what can I check? Is there a gear behind the dash or something digital that needs replacing? Thanks!
There's actually some kind of infa-red sensor and wheel back there. I read a post somewhere awhile back on how to fix the 85mph limit on the disco dash.
If anyone has a link to that there's acutally a ton of info on the digital dash, how it works and what to look for if it breaks.
Guest
Posts: n/a
I have a 1983 280zx with the same problem. My speedo reads "0" also. I took it to the Nissan dealer and they said it had a bad circuit board. The part number for that is 25935-P9700. They couldn't locate the part for me and I've been unable to find it also. It sounds like an easy fix because they were only going to charge me 30 minutes for the labor if I brought them the part. Hope this helps.
Z92AL
04-11-2013 10:39 PM
