engine stalls....
Old 05-01-2004 | 12:11 PM
lifegrddude's Avatar
Externally Wastegated
When you take the filler cap off, you're creating a massive vacuum leak. That's normal for the engine to stall. If it doesn't stall, then you'd have to worry.
John 82ZXT
Old 05-03-2004 | 03:46 AM
cerealkilla's Avatar
the l28 is equiped with an oil pressure safety switch. this helps by retarding the ignition when you loose oil press. it really helps when your driving down the road and you blow a seal and dump all your oil. it will kill the engine so you "shouldnt" seize your bearings. this does not work all the time. i know.
84z
04-12-2014 07:50 PM
nerdbebo
05-22-2008 12:45 PM
drisky
10-27-2007 05:03 PM
venom8343
10-15-2006 01:43 AM
buffet33
03-22-2002 05:11 PM
Quick Reply: engine stalls....
