External Wastegate
Old 07-03-2007 | 08:11 AM
Nemesis280zx's Avatar
External Wastegate
I just got done searching the forum on an external wastegate setup and how to, but didn't anything, so I'm wondering if anyone knows how to do an external wastegate on the Turbo L28. I have a T3/T4 Turbo on right now. Which one is a good one? What is needed to do this external wasategate? Thanks.
Old 07-03-2007 | 08:23 AM
Lifegrddude has an external wastegate. There are a couple ways to do it.
#1... Take a plazma cutter to the stock exhaust manifold & cut a hole to weld on the wastegate pipe.
#2... Make a "manifold to turbo" adapter that's about 2" thick & cut a hole in the bottom for the wastegate pipe.
#3... Make your own exhaust manifold runners & collector, with a wastegate pipe.
Old 07-03-2007 | 09:29 AM
where do I find this wastegate from lifegrddude?
Old 07-03-2007 | 09:42 AM
RodMoyes's Avatar
Doesn't post much...
Dude,
He was parked two cars away from us at MSA...
Send him a PM.
Rod.
Old 07-03-2007 | 09:46 AM
Oh hes a guy from here, thanks. Which did he have? Does anyone have pictures of this setup?
Old 07-03-2007 | 09:50 AM
http://www.cardomain.com/ride/341756
Old 07-03-2007 | 10:03 AM
veyenyl's Avatar
Nismopick's option #1 and #2
Attached Thumbnails External Wastegate-tial_wastegate.jpg   External Wastegate-turbo_wastegate_adapter_005.jpg
Old 07-03-2007 | 10:07 AM
With the adaptor, does a large turbo clear the steering arm?
I see it is angled up a little... hope that's enough
Old 07-03-2007 | 10:08 AM
^^^ Nice! You have an external don't ya Veyenyl?
Old 07-03-2007 | 10:27 AM
Where does the other libe run to from the wastegate, back to the exhaust? Where?
Old 07-03-2007 | 10:37 AM
Yeah, it just needs to bypass the turbocharger. Usually it's run back into the downpipe. Lifegrddude has his dumping to the atmosphere... which is loud at full boost.
There's lots of info on the web about internal / external wastegates & which should be used for a specific motor. Also, you should read the book "MAXIMUM BOOST."
Old 07-03-2007 | 10:53 AM
veyenyl's Avatar
Mine is internal. Works fine for me on a street driven car. As far as clearance using the adapter, that has to be worked out for each individual application.
An open wastegate dump sounds like a wild banshee at full boost
Old 07-03-2007 | 11:22 AM
lifegrddude's Avatar
Externally Wastegated
Hi, yes I'm using an external wastegate. It's mounted on the #6 runner of the manifold which isn't optimal, but I didn't buy a prefabbed spacer for the wastegate at the collector, and I didn't have lots of clearance with the steering. Not to mention trying to route a pipe away from the rubber boots of the tension rods. (I would have if I'd been allowed to weld, but I can't in this neighborhood) If I could do it over, I'd mount it at the collector. As long as you're not getting boost creep or unstable boost, an internal is fine because an external gate that's vented is friggin loud. Don't vent it next to a concrete median divider with the window down, your ears will thank you.
Old 07-03-2007 | 11:35 AM
Nemesis, I tried sending a response to your pm, but your inbox is full, I'll send it again later.
Old 07-03-2007 | 12:21 PM
KTM200-280zxt's Avatar
Tomorow Im going to take some picures of the progress on my car, I will post some pictures of my external wastegate setup, its mounted between runner 4-5, im in the process of fabricating the dump pipe but everything else is finished
Old 07-03-2007 | 05:01 PM
Cool thanks, has it been easy doing it for you? I will be swapping my motor into the 280Z maybe next weekend, if not for sure the following. I was thinking about doing this external wastegate while the motor is out. I will be Mega Squirting it too with the swap.
Old 07-04-2007 | 01:58 AM
Heat Rave R's Avatar
Is there any negative downside to venting to atmosphere (like how a BOV venting to atmosphere messes with the A/F)?
Old 07-04-2007 | 03:34 AM
nothing really, the computers stop reading the fuel mixture at 3k rpm's
Old 07-04-2007 | 07:13 AM
Its pretty easy,I will go snap some pictures shortly, and I wouldnt do it with the motor out of the car because its hard to test fit everything, and its all a real tight fit, atleast in an S130.
Nope just reallyyyy loud, i plan to use it as a horn. lol
Old 07-04-2007 | 10:10 AM
Ill take some better pictures but I couldnt find the right camera lense so its a horrible picture
Old 07-04-2007 | 01:01 PM
that TIAL is tiny!!!!
Old 07-04-2007 | 03:40 PM
hmmmm maybe its the picture? its a 38mm, no big but not tiny
Old 07-04-2007 | 03:48 PM
You're talkin' crazy.
Old 07-04-2007 | 04:02 PM
lol, im used to my friends DSM i think its more like a 60mm or somethin around there, and those tial BOV are huge
Old 07-04-2007 | 04:09 PM
60mm=3inches. I highly doubt a dsm would benefit from a 3 inch diameter wastegate. That's bigger that his main exhaust pipe.
Quick Reply: External Wastegate
