First post since may, more turbo z280 crap.
Old 02-03-2006 | 10:04 AM
MetalZ's Avatar
Hey all. Hope is revived! I found out what this little bolt with a wire was. It's a thermo time switch. I'm ordering one from napa today. Can anyone tell me exactly what it does? Thanx and peace.
MetalZ
Old 02-04-2006 | 12:09 AM
If It Has One Green Wire From It, It Is For The Coolant Guage And It Also Helps The Computer Figure Out Engine Temp.
Old 02-04-2006 | 11:04 PM
jfairladyz's Avatar
Actually the yellow wire feeds the signal to the guage. The thermotime switch controls the cold start valve. Problem is the turbos didn't have a cold start valve, so they shouldn't have a thermotime switch. I only say this cause the word "turbo" was used in the title of the thread. So if it's not a turbo then the above about the cold start valve applies. The signal that feeds the ecu the eng temp comes from the cylinder head temp senor which uses two wires. I dont know their colors but it uses the same connector as the fuel injectors. The other thermal sensor is the temperature switch that sends the signal to control the aux. cooling fan. So what color is the wire/wires.
(of course Canadian models could've been different and the above only applies to 81+ because you mentioned turbo.) I'm not sure on wiring colors on pre 81 models.
Comrade_Charlie
FS: 300ZX (84-89)
10-13-2007 12:22 PM
David703
04-29-2007 02:41 PM
Carl's Z
03-12-2007 08:19 AM
mattduskater
08-02-2005 02:32 PM
silvrhand
10-25-2001 07:38 AM
