Fuel Pressure Reg
Fuel Pressure Reg
I just got an Autotek adjustable fuel pressure regulator. I put it in-line like I thought it should go, didn't come with any instructions. I removed the old regulator and connected the lines where the old one went. Now the car won't start.
Can someone give me some advice on where the regulator will go on a stock fuel rail? Any help is appreciated.
![Fxloc](https://www.zdriver.com/forums/images/smilies/fxloc.gif)
I put the regulator in the line that comes out of the fuel filter to the fuel rail. The fuel pump will come on and pressure up to about 20lbs, then the pressure bleeds off for some reason. It's not holding. Prior to putting the new regulator in the car would run fine, just thought it would be better to be able to make adjustments if needed.
yoshi8976
09-05-2003 05:35 PM
