fuel pump UUUGH
Old 07-01-2011 | 07:06 PM
MSZKIDWELL's Avatar
Exclamation fuel pump UUUGH
new injectors, new fuel pressure regulator, both relays replaced, new fuel pump and still it only comes on when it wants. sometimes you can turn the key and hear the fuel pump other times it won't come on. not sure what to do next??? if the fuel pump comes on i may strike a match. it is a 1983 280zx with a turbo. 72000 original miles but sat for years.
Old 07-01-2011 | 11:13 PM
borini63's Avatar
Is your car run?
If you don't hear the fuel pump some times that means your system has enough pressure.
Jamal
Old 07-01-2011 | 11:52 PM
rogerz's Avatar
Grumpy & Helpful
check your battery and cables. loose and or corroded terminals can cause intermittent problems. borini is wrong there is no pressure switch to cause the pump not to run. there is a time delay for the pump to run short time when the key is in the ignition position before going to start position. once started the pump should run continuously. also you could have a bad ignition switch. hot wire the pump and see if it runs
Old 07-02-2011 | 08:45 PM
MSZKIDWELL's Avatar
Checked all connections everything looks good. I know it is a power problem. You can turn the key and sometimes it comes on and sometimes it doesn't.
Old 07-02-2011 | 09:47 PM
Check the wiring under the column, pull the plug on the ignition switch and jump the ignition wire a few times, I'm betting its the switch, or you have a short. Also don't forget to check the connections at the fuel pump and try disconnecting and reconnecting the ECU.
Old 07-04-2011 | 12:59 PM
ls1angela's Avatar
i have an 83 turbo that did the same thing . when the pump is not running , do you have spark and injector pulse ? i replaced the ecm , problem solved .
ThatDude114
06-15-2014 09:43 AM
RonK
02-11-2013 09:48 PM
sameerb1
03-20-2011 06:21 AM
ern
10-20-2006 08:01 AM
280ZXtreme
04-10-2001 08:00 AM
