Gaskets
Old 10-03-2005 | 12:11 AM
jmmorriso's Avatar
Gaskets
I am getting a intake to gasket match and blend for a 60mm TB. Which intake manifold gasket should I go with? Can I get away with port matching the head in the car or should I just pull it and deck it and raise the C/R while Im at it? Has anyone cc/ed a 81 zx motor to know how much I can deck off of it?
Old 10-03-2005 | 09:03 AM
The factory intake manifold gasket has larger opening than the runners. Port match the head and manifold to the diameter of the gasket. That should work well for you.
Old 10-03-2005 | 07:25 PM
jmmorriso's Avatar
can i still get gaskets from nissan? will they still be good after sitting on the shelf for two decades?
Old 10-03-2005 | 09:24 PM
jfairladyz's Avatar
You can still get gaskets from Nissan. I got suckered into buying one when the local parts stores didn't have one in stock and the dealer did and I NEEDED it ASAP. I payed a little more for it as a result. As far as whether they're still good, Yes. I used the gasket without any problems what so ever. I ended up having to replace because I tore it while repacing my exhaust manifold. But it gave me no troubles for the year and a half it was on there.
BlueKitsune
07-29-2013 08:36 PM
Texaz
10-05-2005 10:57 PM
assimilated420
04-13-2005 02:42 PM
attworth
10-22-2004 11:55 PM
guru22
01-04-2002 01:47 AM
