Heater control valve
I have a 1982 280ZX that needs a new heater control valve. It origionallt called for part #27116-P7100 but was redesigned and now goes by part #27116-P6500. What I want to know is what modifications and / or changes need to be made as the two parts are not very similiar?
Do you have auto or manual climate controls?
I know one of the valves had a thermo coil that ran to the heater core box, and later replacement versions didn't include it (no side effects).
Discussed here:
https://www.zdriver.com/forums/280zx...roblems-22982/
and
https://www.zdriver.com/forums/280zx...6-p7100-28580/
Discussed here:
and
Hopefully you clicked those links I posted?
yup got it to work... i had to cut the coil off the old choke valve cuz i didnt know how to remove it from the heater. the mounting screw were in diffrent locations but it still mounted right... i had to adjust the cable and push/ pull pins but all in all the new choke works just fine...
WillbeWild79
04-30-2005 12:14 PM
