Hello, 1st post-trying to get the Z started
Old 08-04-2011 | 09:26 PM
  #51
Originally Posted by garretthes
The short was a ruse. The problem was that a quick blow 20 amp fuse was not enough for the load. After replacing it with a slow blow 30 amp it works great. Everything in the dash works now except maybe the clock
We had it running great. However, after fixing the brakes and clutch now I have a white smoke problem. It's dumping fuel bad and back firing. Plugs are wet with fuel. I tried clamping the hose from the cold start valve and it cleared up. What would cause this valve to stick open? Is it getting bad info from another sensor?
I'm assuming you're running the older glass GMA style barrel fuse about 1.25" long? What is the fuse that is suppose to be installed in that socket rated at?
Old 08-04-2011 | 09:33 PM
  #52
garretthes's Avatar
No I'm using modern blade fuses. Everything works now except the blinkers which I haven't even looked at yet.
Old 08-04-2011 | 09:38 PM
  #53
garretthes's Avatar
OK, dumb mistake. Was thinking the fuel ran the other way. The rubber line has pressure all the time.
I pulled the cold start valve and tested it. It pulses fine.
If I run the car with the cold start valve electrical disconnected in runs OK, maybe still rich but certainly doesn't smoke and blow fuel out the exhaust. I discovered the first injector is not working. This really sucks because they were all working.
Well...it ran OK for a while. I took my daughter for a short ride around the block and it completely crapped out. Would barely idle and maybe on 2 cylinders. Had to push the car home.
Really frustrated with this car. Ready to rip this ancient sh*t out and install an LS3.
Old 08-04-2011 | 09:43 PM
  #54
Blade fuse come in fast and slow blow? Is the 30A fuse the correct fuse for that circuit - eg does it match the value on the fuse block cover?
Old 08-04-2011 | 09:46 PM
  #55
The issue is the wiring/electronics not the engine. You're just as likely to have wiring issues with an LS3 as you are with an L28... Are you sure the ECU is working properly? Did you check the AFM connector?
Old 08-04-2011 | 10:03 PM
  #56
garretthes's Avatar
Yes but I'm way more knowledgeable on the LS.
Not sure about the ECU. I will test the ECU in the morning. The AFM connection hasn't been touched and feels secure.
This car sat up in a field for two years before we bought it a year ago. Yes, I have been working on it a YEAR. At one point we had it running nicely. Now that I can actually drive it... not so nice.
Old 08-04-2011 | 10:34 PM
  #57
garretthes's Avatar
Sorry I missed this...
The blade fuse is a replacement for the fusible link.
Old 08-04-2011 | 10:36 PM
  #58
garretthes's Avatar
By the way I love BC. Been to Vancouver a few times and love it there. Especially in the spring
Old 08-05-2011 | 09:08 AM
  #59
Unfortunately I'm buy myself and it only gets power when the starter is running or the engine runs. I did finally notice some fuel coming out. It stinks too. I added 2 gallons of fresh fuel but it still smells like kerosene or something. May need to add more new gas.
The truck in my avatar is a 59 Apache Suburban.
A couple of random things... if you have power windows there is a breaker/fuse... lol I was searching for a thread for you but it looks like you've already done your homework
http://www.classiczcars.com/forums/s...window-breaker
Just wondering if you did some of the basics like drain the old gas from the tank, make sure the fuel filter isn't clogged and that you are getting good flow from the fuel pump? When you turn the key to the "ON" position the ECU tells the fuel pump to run for a few seconds then shuts it off. That brings the fuel pressure up.
Did you check flow on the injectors? You can set up a rig to measure flow to see if they are in spec but it's likely that one or more are working just fine so you could probably figure out if they are working all the same. I think you can activate them with a little 9V battery or just apply 12V to them. They are meant to be pulsed off and on and you usally run them max at 80% on so don't leave them on forever - just long enough to check the flow on each one.
This is a pretty simple setup and it's the same as any other engine - fuel, spark and air... it hard part isn't fixing it - it's finding what's wrong with the apparently simple system
Old 08-05-2011 | 10:09 AM
  #60
garretthes's Avatar
Thanks for the link. This thread is almost a year old so some of it is out of date.
I did fix the windows.
I had to replace the fuel pump. It was dead.
I went through the fuel rail completely and replaced several injectors from the parts car and all the rubber. At that time all injectors were working. We drained the fuel from the tank when we replaced the pump.
Fuel filter is new.
Also replaced several vacuum lines.
Old 08-06-2011 | 09:43 AM
  #61
garretthes's Avatar
Ohmed out the EFI system.
The following systems were included:
Idle Throttle Switch-OK
Full Throttle Switch-OK
Air Flow Meter Resistance-OK
Air Temperature Resistance Sensor-OK
Water Temperature Sensor Resistance-OK
Air Regulator and Fuel Pump Circuit-OK
ECU grounds (4)-OK
Discovered some corroded contacts on the idle throttle connector that were affecting readings. Cleaned them then cleaned all the Fuel Injector connectors and Air Meter connector.
Engine still missing. Will check for fouled plugs next. Just put them in though.....
Old 08-06-2011 | 05:22 PM
  #62
garretthes's Avatar
Cold Start Valve is working properly.
The Manual states that when the fuel pump is running the pressure regulator is supposed to buzz. I listened and it was silent so I swapped it out. The 2nd one is also silent.
Currently the car starts very quickly then runs rough then runs worse then dies.
The plugs are all good.
There is one injector that is not firing but is getting pulsed. This does not account for it running like crap.
Old 08-06-2011 | 08:07 PM
  #63
eh? How does a 6cyl running on 5cyl not account for running like crap? I've been through many sets of these old injectors and can tell you that one bad / clogged injector will make the engine run rough. It shouldn't die though...
Every time it dies, does it start right back up?
Old 08-06-2011 | 11:08 PM
  #64
garretthes's Avatar
Right, it does run bad but then after about 20 seconds it changes and BARELY runs. It switches from bad to terrible every time. After it dies it will not start for a while. Come back an hour later...starts right up like a champ. Then 20 seconds or so it goes to barely idling then nothing.
Old 08-07-2011 | 02:13 PM
  #65
An engine needs 3 things to start:
-air
-proper fuel
-proper spark
So when it won't start, is it not getting fuel, or not getting spark?
Old 08-09-2011 | 12:32 AM
  #66
Your ignition needs three things to fire the coil correctly. The magnetic fluxbands must be in correct timing with the crank and the synchronizers must be in photomodulaic comparison with the isorhythmic bands in the ECU..
All complete bullshit though, do what nismo says...
Old 08-09-2011 | 07:28 AM
  #67
garretthes's Avatar
Made me laugh though
Old 09-20-2011 | 11:45 AM
  #68
garretthes's Avatar
Update
Spoke with a Z mechanic in Nashville. Did some troubleshooting over the phone. Turns out the short harness from the coolant temp sensor was shorted. It would read correctly on the meter until I started wiggling it around....
After replacing it the engine runs much better, no smoke at all. However, I still have a miss.
Engine work has stopped to make room for body work. I'm trying to get it painted before the cold sets in.
It is driveable now though.
Tooquick260
02-26-2013 04:56 AM
Lanoi
04-07-2010 11:45 AM
RodMoyes
11-02-2005 11:37 PM
assimilated420
05-04-2005 07:51 PM
Skully
04-08-2004 04:15 PM
Quick Reply: Hello, 1st post-trying to get the Z started
