how do i get my timing chain on?
#26
Originally Posted by 280zExTURBO
dammit! whats involved in taking the pan off? anything special?
Once you get the pan off, you'll need to remove the timing cover.
Once the timing cover is off, you'll be able to re-seat the chain tensioner.
When you do, put the chain around the cam sprocket and make sure you line up the timing marks on the chain.
Don't forget to make sure the engine is at top dead center or your motor will be off and you'll have interference between the valves and the pistons.
#27
there is no "timing belt." just the chain, which unless it breaks or gets a lot of slack, doesn't need to be "serviced."
If ya gotta take off the cam gear, shove a good piece of wood between the chain so it won't slip & loosen the tensioner.
Don't you have a Checker, AutoZone, Napa, or Pepboys near by? They all should carry repair manuals... for $10 - $15.
Autozone didn't have it for my 280ZX. I didn't check Napa, and I don't even know what the hell Checker or Pepboys is. Anyway, as for the timing chain, isn't it recommended to change it every 30,000 miles or no? Am I just thinking of the timing belt?
#28
#29
Originally Posted by RodMoyes
nice! Line 1: "WARNING: This is definetly not to be tried by someone & stupid and inexperienced"
#30
Well just the one thing I've been wondering. Are you supposed to change the timing chain every so often? I know on the Z31 they said to change the belt every 30,000 miles. I guess this would be alot longer since it's a chain.
#31
The Z32 (2nd Gen 300ZX) recommends changing the timing belt every 60,000 miles at a cost of about $1200 (mostly labor).
I can't imagine the Z31 requires service at half that. And, I thought the Z31 still had a timing chain.
#33
The Z31 had a belt. I know the L-series engines have a chain. I just didn't know wether there was a recommendation on changing the chain every so often. The original owner of the 280ZX thought it had a belt, so he was saying he thought every 60,000 you were supposed to change the belt or chain(since he wasn't sure). So based on that, I thought maybe you were supposed to change the timing chain every so often. I guess it would make sense that for a big metal chain, you really wouldn't need to change it. Yea, I've changed the timing belt on a Z31 so I know it did have the belt. The main thing I've been wondering was just that does the Timing Chain in the 280ZX and earlier have a certain mileage that you're supposed to change the chain at?
#36
Alright, thanks for the help guys. I just didn't know there was such a big difference between the chain and a belt, but it makes me wonder. If chains are so much stronger and last so much longer, why did they go to using a Timing Belt?
#37
The chain almost never fails on these cars. The weak link (no pun intended) are the tensioners. When they go bad they can cause a lot of slack and noise and other nastiness. I've never seen one of these chains break though. It's very over-engineered. When my buddy and I changed his a few weeks ago, his dad was helping out, he's a hard core chevy guy with a seriously built chevelle and he was impressed with how stout the chain was. Like L-Dub said... you'll destroy the motor before you break the chain.
Rod.
Rod.
#39
ok... I got the car to turn over ...I never matched any marks up...maybe thats why flames shoot out of my exhaust manifold.
what did i do wrong? LOL
I think im going to sell it and get one already running. 800$ cash 1982 280zxTURBO
LOCATION ATLANTA GA
LOCATION ATLANTA GA
#40
I never matched any marks up... what did i do wrong? LOL
And feel free to list items for sale in the MarketPlace.
#41
Flames shooting out of the exhaust manifold? Assuming there were no horrible noises upon startup, and the car actually started up correctly, and idled, you probably put the chain on right. As for fire....no idea. You've got a car out of the Fast and the Furious apparently, either that or the next Batmobile.
#43
Sounds like ignition is out of time.Remove dist hold down screw and turn dist with some one craking to see if it will run.If you get it to run right like that,then you have to drop the oil pump and realine the dist.
#49
huh? Explain thee whole screw thing..sounds like ill get the **** shocked outta me. And #1? whats #1? im a noob to this timing stuff.
If you don't have that piston at Top Dead Center (TDC - where both cam lobes for that cylinder are closed) then your timing will be off. It sounds like it's sparking on the exhaust stroke which means your distributor is on 180 degress backwards.
You'll have to remove the oil pump to re-align it.
#50
i wouldnt worry about fixing that Z yourself anymore. just sell it. dont take on more than you can handle. it will just turn you off to the project and cost you money, time and agrivation.
