Idle High help Plz
Welcome to ZDriver!
When did this problem start? Did you recently do any work on the car? The more info you give us, the easier it is to help you.
-Check the timing
-Check for vacuum leaks
-Check for any disconnected sensors
-Check the timing
Check all your sensor connectors, and make sure they are clean, and have good contact. Also if that doesn't help, check your injectors, and make sure they are all working correctly. That should give you a start, good luck man.
you can also clean the green off with baking soda. make a paste and it will fizz. the wash it off with water when the fizzing stops. no bush required. it will also take corrosion off where the brush cannot reach, even up the wire sheathing. running rich can be the afm, too high fuel pressure, bad plugs, temp sensor, cold start valve stuck on and o2 sensor
I Cleaned My Connectors Checked For Leaks No Leaks and I Checked My FPR And It Was Leaking Through The Diaphram So I Changed Now It Rinning Better But Still Hanging And Running Rich I Also swapped My Afm from My other Z and It Ran The Same
Check the injector pig tails. Also the IAC might be sticking.
Also seen this problem being related to a faulty power steering pressure switch or A/C pressure switch. Which bumps the idle up when engaged to keep the motor from bogging down.
I Never Thought about The Power Steering Thing It has been Acting Up On Me Tho I Makes A Tiking Sound Sounds Like A Rod Knock And When I Took The Belt Of It Stopped... Now The Idle Doesn't Hang As Much Now It does It Sometimes And Sometimes It Doesent :/
You are right, it does not have a ps switch, but has a/c and oil pressure. Though after thinking about this it seems more like a throttle body problem. Try cleaning it, if that doesn't work I would try adjusting the tps and or iat to see if it makes a difference.
madkiwi
06-06-2015 07:40 AM
