injector problem
Old 06-29-2013 | 04:40 PM
tamug92's Avatar
injector problem
any ideas on why my injectors at nbr 3, 4 and 5 wont fire but the others do? I can get the engine to start/run but it's rough. Pulling the connectors from injectors 3, 4 and 5 don't do anything to affect the engine while running. pulling any of the others will cause it to shut down.
I thought I had bad injectors (they are all new) so I pulled the 3 that arent working and replaced with 3 new ones. No chnage.
I'm perplexed and out of my skill set here. It's got to be something simple?
any ideas amigos?
1983 280zx non turbo..
Old 06-29-2013 | 10:13 PM
Are the injector connectors corroded? Loose? Burnt?
The first thing to do is get an injector noid light to make sure all 6 injectors are getting power. If some are and some aren't, the injector harness is probably toast (FricFrac sells a harness fix kit).
If all 6 are receiving power, check fuel pressure. Also, mix and matching injectors doesn't always mean they will work. We've discussed in the past ways to rig up an injector test station.
Old 06-30-2013 | 07:16 AM
tamug92's Avatar
thanks for the tips. All the connectors look fine, fit snug, arent burnt so I'll check out the tester you mentioned. otherwise it's going on the trailer and off to Awesome Z on Monday..
Old 06-30-2013 | 08:38 AM
tamug92's Avatar
ECU light?
another observation, the green light on the ECU is on/off intermittantly while engine is running. Should it be on continuously when running?
I have checked everything else except I have not made or purcahsed a noid light yet.
Old 08-15-2016 | 09:49 AM
Anthony Moran's Avatar
Are you still here ? I have the same problem how did you fix it?
any ideas amigos?
Zemerkenator
02-19-2010 04:10 PM
hchase17
05-12-2009 08:14 PM
Z'sOwnTheRoad
05-14-2006 10:46 AM
81 Black L28E
07-08-2005 05:54 PM
OutLAW Z
04-30-2004 08:25 AM
Quick Reply: injector problem
