Injector Swap Help
Injector Swap Help
Ok so I have a 280zx N/A and I have recently decided to buy a new fuel rail... I have the option of a rail to work for the stock injectors, and 11mm bore rail for o-ring injectors...does anyone know a good set of 11mm injectors i can use and a good regulator, ECU, and anything else I would need to get the bigger 11mm injectors to work
Thanks
Thanks
Click: https://www.zdriver.com/forums/280zx-s130-forums-77/horsepower-heh-32606/
Stand alone fuel management, $10k. Done done.
A turbo motor swap is always the easiest & cheapest way to make power on these cars. Unless you are a die-hard n/a fan, and have gobs of $$$ to burn, go the turbo route... and no, piecing together a turbo motor isn't a "good" alternative.
If any of you guys live in florida a hear of someone selling a complete turbo motor that is not asking a retarded amount for it let me know then cuz i have been wanting to do a turbo swap anyway
nope. just needed to get the car running right and a buddy of mine had the parts i needed but off a turbo car. also did the dizzy, mass air flow and timeing. she runs like achamp now. getting it ready for boost
datdude407
09-13-2010 09:44 AM
