intercooler ???????
Guest
Posts: n/a
intercooler ???????
need to fing a intercooler for my 280zx but the one i can one find its in motorsport but it caused alot i need a cheaper one any of u guys have any place were I can find good cheap intercooler
Am running boost controller 9-10 pounds w/o intercooler
THANKS
THANKS
Guest
Posts: n/a
Im no expert but id look for some intercoolers in your local junkyard, heard of people using isuzu intercoolers and other random intercoolers used on crappy cars. They may not be able run at the boost you are looking for, so its best to do get some info on what some of these intercoolers can do, but they will be alot cheaper than gettings something from MSA or a speedshop/whatever.
if i were you and you jsut need an intercooler id go with the 87 - 89 toyota supra turbo one... it might not be as flashy as some out there but it does the job.. and its prolly a lot cheaper too... and since its a intercooler from a supra (which is a 6 cylinder too) its perfect for your application...
You can also use Spearco units. I got one with piping for an early Z from a guy that posted on zcar, and I just have to modify some of the pipes. I'm hoping to that this summer if all goes well. Spearcos are good i/c's, they have the bar and plate design and the larger mass so they can act like a heat sink at lower speeds. You can check out their site for info on dimensions and stuff, they don't make a kit for a Z or ZX.
John 82ZXT
John 82ZXT
Guest
Posts: n/a
Spearco's are definitly good IC's...they just cost $$$ As for the piping, there is no bolt on piping for the ZX. Again, unless you have the $$$ to burn then you can spend that on the kit that Motorsport sells...that's a bolt on. But if you don't mind getting creative, then you can get mandrel bents and fit them yourself. I used 6 2.25" mandrel bent pipes. 2 45degree bends and 4 95degree bends. Got them from Alex Costa of Precision Engines for a little over a $100.00. Don't have his info anymore but you can go over to zcar.com and do a search about piping...his name WILL pop up. Good luck.
FYI, the kit that Motorsport Auto sells is the HKS kit, it's way cheaper at other online sites like www.optauto.com, they have some stuff for a ZX that's a couple bucks cheaper. The HKS kit is like 500 dollars cheaper there... Search around for an HKS intercooler with a search engine, but yeah, I think it'd probably be better to go the route RatedZ went, it's better bang for buck.
John 82ZXT
John 82ZXT
Guest
Posts: n/a
I bought a spearco 2-221 intercooler and have a total of 5 90 degree bends in my entire intercooler plumbing. I fabbed it myself using 2.5 in mandrel bends, and if you want to struggle, use 2.5, 2.25 would probably be easier to work with.
I also had to run a 3 inch pipe out on the same side for the Ford Cobra MAF the JWT set-up runs, so as you can imagine, it is cramped.
Here is a pic before I painted it, and plumbed in the BOV and that hose for the AIC.
Guest
Posts: n/a
Here is a front shot without the hood or the 3 inch line for the maf.
The car is not beautiful, but it is the test bed until I find a nice one, break down and paint it, or get a 240-280Z.
Here is also a personal opionion on intercoolers. It is better to get one like the one I have if you have a turbo under a T-series, since the pressure drop from intercoolers with long passages is hugher then ones with short passages like mine.
Yes the longer passages are more efficient, but you run the risk of putting your turbo out of its efficiency range by having to raise the boost to compensate for the pressure drop. Better to have a slightly less efficient core with low pressure drop when running a hybrid or smaller turbo.
Also, a stock intercooler from just about any car is not designed to cool air for a hot Z engine that is turbo charged. Some may work ok, but you would be wise to spend the money and get a good cooler to start with.
This one is 18.48x6x3.5 with 2.5 inlets and outlets. It flows 1050 cfm at 1.5 psi pressure drop.
Great pics Lockjaw, I have an i/c that's identical to yours I think. Or at least very similar. I haven't taken measurements, but it's a Spearco and has the same shape and outlets too. Those pics are going to be a good reference point for me when I do this i/c install. How much of the frame did you have to cut out? What did you use to cut the frame with? Just trying to get an idea of how long and what to expect of this project. Are you using a 240SX throttle body by chance?
John 82ZXT
John 82ZXT
Guest
Posts: n/a
Yes I have a 60mm TB from an 89 240SX, which I believe is the easiest to use.
I had a hole already cut there from the previous owner, and I think he used a sawzall. I just used a carbide cutter on my grinder and opened it up some more. I went from small, like 2 inch pipes to 2.5, and the intercooler used the same sized inlets, so this is a big increase in flow for me.
It is a very tight squeeze, and I actually had to cut the bottom mounting bracket off the radiator to make it work.
I also had to grind some metal off the bumper shock on that side of the engine, but I took off just enough to get the pipe in there, but it is tight enough to keep that line from blowing off under boost.
I tried not to bludgeon anything, but if I would have had a plasma cutter, I could have done a nicer job. Much nicer actually.
I've heard from others that a 944 i/c is okay to use, but don't quote me on it. I've never seen a 944 i/c up close, but from the pics it looks like it's good to go. How much boost is a relevant question as it all depends on i/c efficiency, pressure drop and all that stuff. I'm thinking 12psi maybe before the fuel system will max out, but maybe lockjaw or someone with more knowledge can give a better estimation.
John 82ZXT
John 82ZXT
Guest
Posts: n/a
I think 12 psi is the generally agreed upon max amount of boost with the stock turbo and fuel system, with an intercooler added.
if memory serves, HKS said if you used their exhaust, air filter and intercooler on a stock 280ZXT and raised the boost to 11 psi, it was good for 245hp. I guess that is pretty good, a 65hp bump. Not sure if they had anything else in there, other then their pressure relief valve since the stock one opens at like 7 psi or something.
I'm running 17lbs. boost with the stock turbo and fuel system without leaning out at all. When I was dialing in the boost, it hit 22lbs. without going lean. I don't trust my stock head gasket to withstand any higher than I'm running now. I have heard from several people the stock internals will handle 28lbs. revving at 7000rpm. I'm afraid with the stock cam and valves I would end up floating a valve or blowing my head gasket! That is going to be my next project--valve/head work to squeeze some more hp out of it.
I just drove it over 1000 miles this past weekend and it did fine at those settings. It's fun to see the Corvette guys reactions when they can't shake you on the freeway! The sportbike guys get a kick out of it too, but they just have to shift again and they're gone!
Hey Lockjaw, what have you done to your fuel system besides the 60mm TB?
-Kel
-Kel
