l24 crank in a l28 block
Has anybody built a de-stroked l28 with the l24 crank. I was thinking of this but don't know if it is worth it. The stroke is shorter so the revs come up but I don't know how much or anything so if this has been done I'd love to hear about it.
Originally Posted by DoTheDrew888
I've heard that the L28 crank can't rev over 7500rpm without vibration problems. Is that true?
having it balanced eliminates those vibrations. Besides, are you really wanting 9000 rpm? What's the rpm goal?
You do realize you better have a majorly ported head, a huge cam, and NISMO competition valve springs. Also, a new ECU or tripple webber carbs.
If you use the same rods as the L28 then your shorter stroke will cause the piston not to reach to top of the block. You'll have 7:1 compression or something like that.
Bore out an L24 block to accept KA24E pistons. (flat tops) They are larger bore than the L28. On some web pages outlining how to build a 3.1 stroker I have seen specs on Nissan piston bore and pin height along with connecting rod length. Using that, you can figure out how close to 'deck height' a KA24e piston will be when used in an L24 block. The KA24e piston is a 3mm overbore in an L28. I forgot how much larger bore the L28 is to the L24. In a machine shop, a bore is a bore as far as cost. 1mm or 5mm won't matter.
AV240Z
04-28-2003 05:04 PM
