Lightweight Flywheel?
Check www.ebaymotors.com I found one on there for $300 the other day. One thing you will have to keep in mind is that the turbo and 2+2 flywheels have a larger friction surface. Almost all the lightened flywheels I have found have the larger friction surface. It will still work on your car, you will just have to buy a clutch for the turbo or 2+2. My personal suggestion would be to go with the larger lightened flywheel and get a Centerforce Dual Friction clutch for the 280ZX 2+2 from MSA. Don't worry it will all fit on your car and will give you that much more "grab" epecially under heavy power loads.
I actually installed the flywheel & a centerforce Dual Friction clutch at the same time, the engine definetly revs faster and I did lower my 1/4 mile time by about half a second but I figure that is from it grabbing harder... But over all I like the setup.. I always figure if you have to go that far under the car replace all at once if possible..
ITSZX
03-02-2015 09:00 AM
slownrusty
04-01-2012 04:12 PM
Jared
FS: 300ZX (90-96)
02-08-2010 07:18 PM
JPerkins
09-17-2007 09:52 AM
