Maxima head
The Maxima head has higher compression. The Maxima uses the L24. The block has a short stroke and dished pistons so the head has very small chambers to keep compression up. When bolted onto an L28 it will make for a higher compression engine.
The Maxima head has smaller valves like a 240Z head so it is not good for high rpm performance right off the car. I suppose it is comparable to the E31 240Z head.
The earlier 280Z heads will give you higher compression but with an open chamber design. Its a toss-up as to weather they are better overall for performance. If you're against head shaving then its one of only a couple ways to get higher compression.
bagpipeswest
12-13-2004 09:37 AM
Quickshift
09-23-2004 01:18 PM
