The most boreing L28.
3mm overbore is said to be the largest safe bore on the L28 block. Add a stroked crank (with a lot of other machine work and mods to make it fit) and you're at about 3156cc or something. Barely able to round up and call it a 3.2L
More commonly called a 3.1L
http://www.jimcookracing.com/catalog/page24.html
heres a 3.1 bore kit for the Z
3.2L is equal to 3156cc why are cc counts not quite that of the L? because even though they tell you 1 cc= 1 mL ...... it is actually .98625 cc = 1 mL... yes theyre both metric but they are very slightly off... i know the numbers seem frivolous but if you get into the whole spectrum of the physics realm of cars.. sometimes even the most minute amounts in certain equations can throw off a lot...
just thought i should clarify that
Yeah but engine displacement isn't exactly an important detail. It's those fractions of inches and millimeters that need to be so specific. a thousandth of an inch can throw a main bore out of wack.
Rebello Racing will do a 3.2L motor, but you'll go through at least a half dozen blocks before you'll find one that will sonic test good enough to go to 3.2L.
Check out: http://www.rebelloracing.com/eng_info.htm
3.1L is much more practical and you won't loose much in performance with one tenth less of a liter except a lot more blocks that will be useable. And that can easily be fixed with boost...
You can get the same 3.1L kit from Courtesy Nissan for $1270:
http://tinyurl.com/8vyxx
Guess who MSA buys their 3.1L kits from? And they resell them for $1800!!
