msa performance exhaust for 280zx
Need a new muffler. Mine has a crack in it. So, today I ordered the msa perfromance exhaust. It has a thrush muffler and the pipe gets connected just after the cat converter. The diamiter is 2.5" V.S. 2" + a liitle for the stock pipe. The new pipe also takes out alot of the turns and jigs that the stock pipe has, give the exhaust gas a straighter exit path.
Hope I didn't make a mistake here. I don't like to spend $$$ then have to spend more $$$ to fix it again..
Check it out
http://www.thezstore.com/page/TZS/CTGY/PEC06
Check it out
+$100 for a shop to install it (unless you have someone who will work for free). So $230 for an MSA kit... or for that same price you could prolly get a custom exhaust made. Either way....
For the most part it is simple enough to install by yourself. Though, if it were me, I would lightly clamp them all in place, tack weld it, drop it, and zap it all the way around the joints for a real connection.
Hmmmm, custom.
Since I already ordered the msa I'll just go with that. You hit the nail on the head, the shop said $100.00 to install. I will ask them to do the welding.
Thank you Nismo.
Thank you Nismo.
I got that kit (2.5inch) for my 240 and really like it. It installs really easily. The only problem I had was the final piece where the muffler connects, it was slightly off align with the rear fender. I got that fixed at a muffler shop for like $60 and it included a chrome tip and welding of the muffler to the piping with a couple brackets. Came out nice
Did you get the turbo muffler?, It has a nice tone to it...
Bouncy, Bouncy.
Don't run with those things, you could poke your eye out.
You should check your springs - or not!!!! lol
Yes, the muffler is the turbo.
Glad to hear it worked for you.
carid
Vendor Specials!
02-25-2015 04:06 AM
280, 280z, 280zx, 280zxt, 79, cost, exhaust, install, installation, installing, materials, msa, muffler, performance, zx
