Newb with questions
Old 09-10-2003 | 09:58 AM
Lazerus's Avatar
Newb with questions
Although I am new to Z cars and this forum, I am not a newb to cars in general. I have a '82 280ZX 2+2 5 spd. And I was looking at doing some head work (port and polish head, intake and exhaust ports, 3 angle valve job). I have already done a complete tune up and fluid change on the car. My real question would be is there a head from a different year range that I should get instead of the one that I have? One that flows better, higher comp., ect. that would make it better suited to build off of. Thanks.
-Matt
Old 09-10-2003 | 11:09 AM
veyenyl's Avatar
You probably have a P79 head. You could go with a P90 head which is used on the turbo motors and is said to be better flowing. It also has square exhaust ports instead of round ones with liners like the P79. Swapping to a N42 or N47 will raise compression to about 10.4 with your flat top pistons.
Old 09-10-2003 | 12:37 PM
Since you're new to Z's but not to heads I'll tell you this much.
Your P79 and a P90 are good heads. Both closed chambered.
The higher compression N42/N47 are small combustion chambers but are open heads. They come on engines with dished pistons.
Open chambers and high compression... 'nuff said
Old 09-23-2003 | 09:03 AM
Lazerus's Avatar
Thanks
Alright, thanks ya'll. I have started looking for the head, just out of curiosity, what size rearend did hte 82 NA 2+2 have. I was just cuirous cause that would pretty much determined what gear to put in there when the time comes.
-Matt
Old 09-23-2003 | 12:13 PM
hellzbellz83t's Avatar
I think it is a 3.90, but I'm not 100% sure on that. Seems like they went from a 3.73 in '78 to a 3.90 in '79 because the ZX was a heavier car. Do a search on this forum for rear end gear posts and you will probably find the answer.
-Kel
anniversary_Z
03-11-2011 04:36 PM
Zetto
10-25-2008 10:47 PM
Seeing Double
07-11-2007 09:08 AM
chicopriest
06-08-2006 08:30 AM
chicopriest
05-31-2006 12:01 PM
Quick Reply: Newb with questions
