No spark 280zxt (help!!)
I searched and couldn't find the answer.My 83 280zx turbo isn't getting any spark.The ecu,ignitor,distributor,coil,afm are in good working condition.I know this because i tested them all on my other 280zxt.
I cleaned all connectors,pulled the ecu plugs in and out 8 times and still no start.I did use one of those spark plug testers.Could a bad ignition switch be the problem?Any advice?
you should go buy a digital multimeter(you can get them at autozone or advanced auto whatever) its only like $13 and it helps ALOT with what your dealing with
one bad wire or connection could be your culprit
I went through two ignitors in three months. Same ****, no spark, it would die at idle, all sorts of weird stuff. Even replaced the CAS(lifetime warrenty, why not.). Bad ground. Cleaned battery terminals, took all the grounds off cleaned em' and put a little grease on the bare metal to cut the corosion. No problems so far and its been 8 weeks, at least. I think those ignitors are pretty sensitive to resistance. Worked for me, FYI.
murdockshady
01-28-2015 06:36 PM
Fairladyz1990AF
04-24-2014 05:15 PM
