Oil Change Tranny/Diff
Gents,
Since I just bought my Z!!!!
I don't know if any of the liquids have been done so I am going to guess they haven't! I'm going to change out the manual tranny fluid, and the rear end fluid, I see how to get the fluid out! But how do I get it back in!!
Also, I found the tranny oil, but what do I use for the rear end oil?
Thanks,
wgcthree
Thanks,
wgcthree
the fill plug on the Nissan 5 speed is on the drivers side of the trans just aft of the bell housing. The T5 fill plug is just above the drain plug on the passenger side of the trans. DONT remove the fitting on the drivers side. Its NOT the fill plug and is not a good idea to remove
On gear oil 75W up to 90W should be good.
In answer to the how you get oil back in, if you mean "how do i pour into that hole when there's no roomto tip the bottles", the answer is you don't. Get a pump gun (like $10 or so at an auto parts store), or borrow one from a friend. It looks like a small household tire pump, but has two hoses. Slide under the car with the pump and the oil bottles, put the suction hose into the first bottle, the outlet hose in the tranny or diff fill ports, and in a few strokes the whole bottle is transferred. Do that til the oil starts to come out the fill plug hole (that's the full mark). Easy as pie. Keep the pump gun in a plastic bag in your garage (no oil spillage that way) for next time.
For what oil, I use Amsoil's full synthetic straight 90 weight (called Series 2k or some marketing name like that). Royal Purple is popular, too.
good luck,
Dave
good luck,
Dave
Originally Posted by WildmaN
That's strange, my fill plug on my 5-speed, is on the passenger side. Does that mean I have a T-5? I don't know about the rear end though. Never messed with it yet. And I used Valvoline 80-90 in my tranny.
moorebl
05-05-2011 08:22 PM
