oil pump shaft
#26
Ignition problems
Take off your valve cover with specified directions, turn engine ay crank with a 1.25 inch socket an bring engine to top dead center by specifications. Now look at the timing chain around the cam gear a shiny link on the chain should line up with the indented mark on the cam gear which should say 1 also.And while you're at it look at your distributor rotor it must point to number position on the distributor cap. That is way i would advise you to start. Let me know what you find after doing that. Cheers !
#28
lost feel like giving up.
I set my 280zx na to 10 deg. Its runs horrible back fire, no power, idles good though. It drives better advanced like to 30. I talked to the zdoc and he said. It could be the weights on the dizzy. (Rebuilt one) I just dont know what to do or check anymore any ideas?
#33
So it turns out timing was perfect......what happened is the crank chuck key broke and ate away at my crank and harmonic balancer. Explaining the messed up reading on the crank. So what do you guys suggest now? I really don't want to pull this engine out.
#34
Update. The woodruff key failed damaged the slot. I'm going to take timing cover off and try to restore it with jb weld and a dremel. Also buying a new pulley since mine Is chewed up. This big head ache for such a little yet major problem. Is the jb weld a good idea? Should I run it without a key for now?
#35
timing no vacc advance
Hey guys. New problem my 280zx na. Idles great but....bad miss fire underload. Timing starts to wander. I fixed all the vacc. Leaks new hoses. Its a new dizzy think it could be the problem? It never had this problem. When I put the dizzy in i could advance and retard all the way but then after its warm it starts to get to max out a 10 degrees. Also what's tat sensor by the ect? (Left of it)
#36
Merged threads AGAIN.
Please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please please stop making a new thread everytime you have a question about the same problem. I hate playing the guessing game of what the problem is and what you've already done. ANY future question / problem you have about your car's timing should be posted HERE.
New as is "brand new from Nissan", or "used, new to you" ? I'm assuming you got a used one since you are doubting it...
I have no idea what you mean by "ect" (me thinks your phone auto-corrected).
sameerb1
03-20-2011 06:21 AM
mikesz
11-01-2007 02:22 PM
ern
10-20-2006 08:01 AM
