oil pumps
oil pumps
so i was looking at upgrading my oil pump and i see the kameari one at msa going for 142.95 and rated for 85.3 psi. I found this other one though which is rated for 90psi and only 99.79 bucks.
http://www.nissanparts.cc/catalog/?section=979
on this site it says they have oil pump springs for 5.99. So question is, (even though probably a dumb one) is it important to get these springs as well?
those other pumps increase volume and pressure. volume is important to help cooling the parts (ie turbo), pressure just gets it there. for instance, if you have an external cooler, then pressure is required. it needs to get oil further away at the same volume.
chaosphere
05-12-2004 06:15 PM
