overheating on the highway
Guest
Posts: n/a
Do any of you guys know what might be causing my Z to run really hot on the highway? As far as I know, there are no leaks in the cooling system. The car does have the original water pump and radiator, however. The fan clutch is brand new too.
thanks
thanks
If the above doesn't work, check the pump and then the radiator. My Z had a bad radiator when I first got it. Took 5 hours to get home instead of 40 minutes! When I replaced it and took a look in the old one... Oh man, the amount of stuff on the inside was frightening.
John 82ZXT
John 82ZXT
You might want to replace the upper and lower radiator hoses as well. Mine had the same problem. I found out that the upper hose, connecting to the thermostat, was weak and collapsed after a few minutes when the motor was up to temp.
bataradena
05-02-2013 06:23 AM
