Please help! The car wont start.
Old 03-15-2010 | 02:51 PM
BlueZX1981's Avatar
My 280ZX Turbo 1981 was working fine yesterday. I drove it about 40 miles but today it just would not start. It is not a battery issue, it wants to start but it seems like there is no spark. Can you please give me ideas.
Old 03-15-2010 | 03:13 PM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
Its your spark plugs, check them. Also, change your fuel pump. Also, change your starter. Also, change your cold start injector. Also change your Auxiliary Air Regulator. Also, change all your vacuum hoses. Problem solved guaranteed.
Old 03-15-2010 | 03:41 PM
SpeciallySpiked's Avatar
I'm a Registered User!
Wow wow, why don't we start testing things before changing things....
Pull one of the spark plugs off to see it's not getting spark. Then go from there.
Old 03-15-2010 | 04:34 PM
skib's Avatar
This facepalm's for you!
he knows all about getting L28's running
but ya, pull the plug and see if its sparking. put the tip of it on a ground (i usually use the strut bolt) and with it plugged in to the wire have someone crank and see if the plug sparks.
moorebl
04-14-2011 03:28 PM
ZXT83
10-03-2009 01:07 PM
dreamspawn
12-20-2008 10:15 AM
JaYaYsSoHN
12-29-2004 12:58 AM
rickyTT
09-26-2004 06:11 PM
Quick Reply: Please help! The car wont start.
