port and polished head?
Old 11-06-2003 | 09:38 PM
FastZ's Avatar
I have an 83 280zx with a p79 head and I was wondering how much porting and polishing should be done to the head and intake to get the most performance. Any information would be great.
Thanks
Old 11-07-2003 | 06:14 AM
Jimmys83Z's Avatar
If you just polish surface would be better than nothing, You have to be careful when removeing materail so you dont remove to much. I dont know of any spec's you could follow and not sure that there are any. I plan on a rebuild for my 83ZXT this winter and I plan on porting and polishing my head and intake as well. I would have head rebuilt then remove valves and polish away. Would only remove enough under valve seat area to make it smooth. On the port side I have heard people using the gasket as a guide, only open port as large as gasket opening I would go through the archives to check for other posts on this. Just remember this when you grind it out you cant put it back. I did find a good site that has kits to polish and port. Its at Ameduri Racing Products its www.fastpts.com. Good luck and let me know how yours comes out or if you find any more info on it............
Jimmys83ZXT
Old 11-07-2003 | 12:09 PM
FastZ's Avatar
I was planning on taking it in to a machine shop and having it done but I just wanted to get a little more info before taking it in. Thanks for the help and I'll check out the website.
Old 11-12-2003 | 07:53 AM
preith's Avatar
Hey guys. I normally stick to the early z section, but I thought I'd participate. My question is, is the P79 head the best one to start with? I'd think a p90, which comes with square ports on an NA motor would be better. It has the same combustion camber volume, so you'd still pass smog. I had this head with flat top pistons on my '77 and it was nice!
As for the porting, its been my understanding that the best thing to do is merely unshroud the valves and port match the ports. This does enlage the chamber a bit, put the compromise is worth it.
Old 11-12-2003 | 09:46 AM
True. The P79 is not the best, but the P90 is hard to find and getting more expensive. P79 isn't all that bad. I think its better to have a closed chamber head with round exhaust ports than an open chambered head with larger square exhaust ports! (ok, the P90 is not open chambered, but the earlier Z heads were)
Power is found mainly on the intake anyway. Since you've got steel liners in the exhaust ports, just unshroud the exhaust valves and do your port matching on the intake. You'll be good. Shave the head, performance cam, advance cam to #2 position with a new timing set, and you're good to go.
Old 11-12-2003 | 02:36 PM
preith's Avatar
I'm a bit confused. By closed or open chamber, do you mean volume? Unless its a typo, the P79 has the same camber volume as the P90, at 53.6 cc's, and the earlier castings, E88 and N42, have a smaller 44.6 cc volume, but compensated with a dished piston.
I have heard of guys removing the steel insterts, any truth to that? Difficulty?
http://www.zcluboftexas.org/128combo.html
Old 11-13-2003 | 09:44 AM
The open or closed chamber is the shape and design of the chamber but not the size. The open chamber is a round dome shape. The closed chamber is a peanut shape with one side having a flat surface that will come very close to the piston on the compression stroke. This forces all the air and fuel mixture over to one side of the chamber (close to the spark plug). This allows for better combusion.
The web page below outlines the open and closed chambered heads of the 4-cyl L-series engines. They look the same on the six.
http://www.worldaccessnet.com/~dcmur.../head_ID_2.htm
Old 11-13-2003 | 12:21 PM
preith's Avatar
Thanks for the info. I doesn't happen too much anymore with the Z's, but I learned something new! What you say makes sense, but from you've said, and what I've read, the P90 is still the way to go.
Old 11-16-2003 | 07:58 PM
FastZ's Avatar
All right, I spun a rod bearing, so I have new rings, bearings(rod and main),and new crank allready in the block. What should I do now to get more power? Which head? What should I do to the head and intake? Most power I could get without nitrous or turbo. Any help would be great.
Old 11-17-2003 | 04:06 PM
True, if you want to do it right get the P90 to start with.
With your block, FastZ, make sure you're running flat top pistons still. Use a P79 or P90 head (which will be closed chambered) and shave the head 0.08 inches. Which is 80 thousanths.
Put in a mild performance cam, stage 1 or 2. With new timing components (new chain, tensioners, sprockets, ect) set the timing chain at the #2 position. This advance will correct some of the slack caused by shaving the head.
Do what you want with your intake and exhaust. Don't open up your exhaust too much. 2.25" is what I recommend.
Old 11-18-2003 | 08:22 AM
preith's Avatar
I agree. If the fuel injection is being retained, only a mild cam is recommended. Also, I can't preach enough, use a single 2 1/4" pipe for street applications.
Old 11-18-2003 | 08:53 PM
FastZ's Avatar
So are the heads basically the same? As in enough difference to make a difference?
Old 11-18-2003 | 09:51 PM
speedgato2's Avatar
i had thought that the best was to have a 82-83 block with an n42 head. is that right or should i now go find a p90? thay is for an n/a motor.
Old 11-19-2003 | 08:47 AM
You heard the N42 was good because those heads have a smaller combustion chamber. They originally came with dished pistons in the older blocks so putting that head on the 81-83 block (with flat top pistons) will yield high compression without having to shave the head. I think about 10:1 compression.
...but they are open chambered and more prone to pinging. You may end up running high octain fuel all the time at that compression ratio just to fight pinging.
P90 is a better head in design, but when used without modifications it still has 8.8:1 compression on the 81-83 block. Shaving the head is the only way to increase compression ratio. well, besides doing other things more drastic.
Old 11-19-2003 | 10:02 AM
speedgato2's Avatar
ok, thanks.
i have a n42 head ready to swap into my zx. i guess i'll go ahead and use it. i don't mind using high octane fuel...i already try to anyway.
should i use 108 octane additives?
thanks.
Old 11-19-2003 | 02:11 PM
only use the additives if you need to. Put high octaine in it and drive it hard and see how the engine sounds. Hopefully you won't need anything more.
Old 11-19-2003 | 09:20 PM
speedgato2's Avatar
arizona gas sucks. i can only find 92 octane here.
hope that is enough.
thanks for sharing your knowledge.
Old 11-20-2003 | 09:30 AM
Oh well, we have 91/92 here in Washington too. I've seen higher octane in Canada but they pay for it!
Old 01-09-2004 | 10:34 AM
FastZ's Avatar
Anyone now where I can get a good cam and timing gears mentioned in this thread. Got some money coming in going to start working on it again.
Old 01-09-2004 | 11:05 PM
dr. buddha's Avatar
Z Extreme Guy
msa or stillen
Old 01-11-2004 | 12:43 PM
speedgato2's Avatar
i just kept digging and digging and digging and diging at the local scrap yards.
i'm in tucson
the yards in phx, out by the airport, are usually pretty well stocked, they don't have any there?
can you recommend any good body shops in your part of the state?
i want to get the msa II body kit put on.
thanks
Old 01-11-2004 | 12:48 PM
speedgato2's Avatar
hey mac
i just saw your post on clubs in az.
i go to phx a lot, are the people pretty cool.
ie. helpful with questions and recommendations?
thanks
Old 01-12-2004 | 09:59 AM
speedgato2's Avatar
great.
thanks mac.
Quick Reply: port and polished head?
