Running rough
Old 12-11-2003 | 08:50 AM
Did your oxygen sensor get replaced? ...or maybe disconnected? Its close to the head pipe.
Even if something was clogging the exhaust like a bad catalytic converter, your idle should be fine. Its the midrange and high rpms that are affected there.
Try adjusting the ignition timing by hand slightly. Don't worry about if its set to factory specs. Retard it a little then try it, then advance it. Usually advancing it smooths out an idle and bring the idle speed up slightly. If you smooth it out, you can bring the idle speed back down with the adjustment near the throttle body.
The ignition timing I'm talking about is just losening that little bolt at the base of the distributor and turning the distributor by hand. Once its at a good spot, tighten that bolt up some. (not too much)
jjk_52
03-29-2014 08:48 AM
steady88
04-23-2013 09:29 AM
mikep
09-28-2007 08:33 AM
tehweej
22
07-09-2007 10:52 PM
91Zman
15
10-24-2005 08:08 PM
Quick Reply: Running rough
