runs very rough
runs very rough
car overheated then stoped running, so i towed it off of the road and checked the plugs for a blown head gasket but no fluid was in the cylinders. I replaced the old plugs and wires that broke when I pulled them out. I can get the car to run but it is very rough and leavs a cloud of smoke behind it. did I blow some piston rings or something or could something have seezed?
It's probably something far less dramatic than a blown head gasket or a smoked piston.
It's probably something far more minor like the plug coming off the bottom of the AFM or a bad connection somewhere.
Start with the basics like that. Check all the electrical connections. Make sure they are all clean, dry and not corroded.
Rod.
Rod.
Location: Houston Tx. Cleveland Tx. New Caney Tx. and every other Tx.
Make sure you have the right gap on your spark plugs that you put in. they don't usally come pre gaped, and if they do you can't trust that the box has never been droped, changing the gap. sounds like a rich condition that could have somthing to do with afm, or a week spark, or somthing like that.
Yeah I used to have a problem with my car billowing smoke. It was weird though cause it only happened when I rolled the windows down
hootie233
07-01-2011 05:37 PM
hootie233
FS: 300ZX (90-96)
07-01-2011 05:30 PM
shaved300zx
08-22-2009 05:40 AM
