Sluggish running 81Z
Hey Guys, I was wondering if anyone here could help me figure out what is wrong with my Z. It is a 1981 ZX Turbo, auto tranny. It wants to sputter, almost pulsing at low rpm's, if I floor it and the turbo kicks in, it seems to run fine. It's mainly at low speeds. It sometimes hard to keep started too. Thanks for all of your input.
Jeff
Jeff
is it doing it hot or cold? also.. it sounds like something with air at idle.. may be your TPS could be going bad or your air regulator needs adjustment/replacement.. it sound like its not getting enough air until you floor it and thats when the AFM opens...
Could be a vacuum leak. Running lean will make it sputter during vacuum, and then the positive pressure from the turbo during boost will leak out making it run rich. Check your vacuum lines, especially those tiny ones on the vacuum pump and even the one leading up to the cruise control mechanism if yours is equipped with CC. Too many hoses in the ZX engine bay, it's hard to keep track of them.
