sputters and backfires at 3000 rpm
Ok here's my problem:
I took the car down to home depot and noticed it was kinda surging and sputtering really bad intermittently. I paid it no mind and got back home and parked it. Today I got in the car for a quick drive, and noticed the problem was back. I checked the timing and it was 20 degrees. The fuel pressure was steady at 38 psi while at idle. I have no idea what is going on. It surges and back fires really bad from about 2500-3500 rpm. I can hear the turbo spooling really really loud but the car is not really moving anywhere. If i floor it, and get past that rpm point, it clears up sometimes.
I am so lost please help!
This is the day of epic nissan fail
Well I know its getting late, but I think I made some progress. I see that there is a vacuum line broken off at the nipple on the evap canister on the passenger side by where the engine bay light is. After fooling with the car, I hop into my 200sx(s12) to go get some bbq ribs. It cranks and drives fine, and after leaving the restaurant, it wont crank. Just spins over. Oddly, a passerby stopped and said to push start it, and I say whatever since the starter is working, but get this, after a push start, it runs; only to about 3500 rpm. So after limping home, My wife tells me her grandad's pathfinder just crapped itself. On a side note, the pathy has 330,000 miles with only oil changes, a t-belt, and a starter ever done to it. Sorry for the long rant, but its just crazy that all these old lemons failed at the same time
is the whole engine cranking or just the starter spinning? cause its possible the gear went out or the mechanism that kicks the starter gear out died. idk, sound lame. where are you from? out of curiosity?
The main thing is I got my Z running right again. I fixed that nipple on the evap canister, and looks like my no 6 injector plug worked itself loose, but after those fixes its running back to normal.
yeah thanks snwbrder for the help. I get so used to saying s12 b/c if I say just 200sx, everyone thinks the newer front wheel drive one (b14).
niku-sama, that is the original motor that came with the car, and I am also thinking it is the maf since it wont rev past 3500 rpm. I dont know, I have been really thinking about selling this junk and really focus on the 280 since it is my favorite car.
frankly i would want the V6 200SX
but any s12's are hard to find unless they have been trashed. theres a nice one where i used to work but i dont think it fo sales
xBlastFemurx
02-12-2013 11:39 PM
